drift can you post up your pics of your setup
did you need to modify any of the mounts or move anything under the bonnet
where did you source the kit from was it local (ie perth)
who installed it (you or a tuning house)
can you get more
how much
must sound like this is 20 questions but everyones a little short on information at the moment so anyone who knows anything is going to be bled dry for info atm
I will get some tomorrow and post them on my site.
We put it back to standard for compliance then bolted it back in a couple of hours and we wernt rushing.
It came with the car but is standard Blitz Stagea kit avialable through most shops, email [email protected] for a price as that is who I get my bits for my car from if they suit Stagea only, I have some body bits coming.
We put it back our self, bit of fairing was already cut out, I will get photos off Jeff at C-Red's car and a standard one tomorrow to show difference.
can you get more
Most Japanese Manufactures make kits to suit the WAGON,
how much
Well price varys and yes you do pay for what you get, I will get some prices through some contacts to set a group buy, but I am 100% sure R33 will fit.
Dont worry ask away, because I deal with the complyier and I think they are the best car at the moment so I know a bit about them.
We will pass our RAWS on a Toyota tomorrow but I still drive a Stagea and it will only be sold for an Autech Version.
Anytime and dont forget to remind me.
  • 6 years later...
To put a end to it all the r33gtst autobarn88 kits fit stageas.
I have 1 on my car its just like fiting it to a r33.
U need to make longer lower brackets and the hole is in a slight dif spot.
I would be careful with ur mods on s1 stageas thow.
I have found out that the ecu dose not really like to have changes. I talked to Cred in perth au and was told a good mod for s1 is to
add a piggy back ecu to the stock ecu like haltech platinum sport 2000.
The stock ecu in s1 controls every thing including the auto fit incorect will cause lots of probs. Was told the stock ecu is the shitty ecu on eney rb
The gain is eney where from 30 to 40 hp on stock motor and 50 to 100ks per tank
I think in the 7 years since the last post we have sorted out the intercooler options :thumbsup: . And yes S1 ecus are hard to chip - Greddy E-manage or Haltech are options or stick in a manual box and a Link!!
I just had a just jap kit put in my car, can't say exactly which one as I got it used of another forum member but yeah it bolted straight in only had to have a small chunk of the reo bar cut out to make it fit, pretty sure it's one of the cooling pro stealth kits which go for about 300-400 bucks, they aren't as pretty as blitz etc kits but it does the job and the engine bay looks very close to stock
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
