Cutting wire 53, put your HICAS into diag mode, Some people have had problems with their HICAS not working properly once the wire has been cut, and some people haven't had any probs at all. I personally would think its a silly idea if your doing a 180km/hr and your HICAS decides to take control over your car ??
BBQ: Have u actually done it or u just heard what other people say? cause i've actually cut the wire and it DOESNT put the hicas into diagnostic mode.
Anyway, HICAS is rubbish, quite annoying really, i agree about the part not wanting the HICAS to start working at 180kph tho!
Check out modyourcar.com.au I got a Pivot speed meter for $152, it removes the 180km limit, displays speed up to 350km/hr and gives you times and terminal speed for 0-100m, 0-200m, 0-300m, and 0-400m.
There are only four wires and it is easy to install, (comes with ecu pinout diagrams for all models). Good value for money i reckon, plus the hicas still works normally.
Lawrence
Yes I have actually done it, I had mine on a switch so when I need to go over 180km/hr on a private road, I would flick the switch. It would give me a HICAS light on my dash though.
Once I turned the switch off, the light would go away.
I though its not safe to be fooling the computer by thinking that somethings wrong when its actually not. So I got a PFC to remove the limit.
From memory.. the stagea's have the ecu wiring of R34, which is different to this wire 53. The only confirmed result I have seen that has worked for the wire 53 is the R33 ecu wiring.
Be on the safe side and get a proper speed limiter cut, not the dodgy wire cutting.
Just my 2c worth.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
