  • Replies 100
I hate bastards who breaks teh window of other people's car...!
that's even worst than your car stolen cuz
1. without window you are most likely your car get stolen and the stuff in the car
2. insurance coverage take long or take long time to process
3. bloody skyline windows are bloody expensive!
4. you have to tint the windows agian!
FFS
me two cents
cheers
Joe
https://www.sau.com.au/forums/topic/5113-todays-west/#findComment-79129
Originally posted by b005t
That is my car on page 3...
who wants to come watch him cry when sentenced on dec 6 :)
I'll be there
Maybe we should all go and give a cheer at the appropriate moment.
I was going to send the bloke a present....soap on a rope
https://www.sau.com.au/forums/topic/5113-todays-west/#findComment-79315
To tell you the truth I actually wouldn't mind coming. I think this would be revenge not only for Boost but for skyline and car enthusiast all over.
I would have to organise half the day off but seriously if we do go we have to cheer when he gets locked up other wise I'm not going to go...... we can't get in trouble for that can we? I reeeeaaally wanna see this coz i have had little buggers brake into my old commy. although they didn't steal it it took dad and I about 8 hours to fix what took them 2 secs to do!
Is parking easy to get there? has a time been given?
Boost i'm sure you will be following this story closely if you or any other of you guys get a time for the court case let us know straight away so people who are interested in coming such as me can get half the day off..... It would be great to see a heap of skylines rockup at this little terds court case!
https://www.sau.com.au/forums/topic/5113-todays-west/#findComment-79354
Originally posted by 25GTT
Oops forgot to ask... i work in West Perth if the court case only takes an hour or so could i pretty please scam a lift of someone? I work just opposite Kings Park....
No sh*t? West Perth ?
I'm in the IBM Centre....
I plan on walking down though :) It's not that far... just the other side of the mall really...
https://www.sau.com.au/forums/topic/5113-todays-west/#findComment-79367
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
