omg thats horn!!!
man i almost feel like getting one now...
those rims are definately 18s.... way too big to be 17s... look at the rubber bands on em... or is it the car makes em look big
man that thing will haul ass once u get some pods on it and tune it for our shitty fuel :D
hmmmmmm mybe i should sell the ceffy :)
WOW...
Got some pods put on today (shitty ones because all the good ones are to big to fit in the limited space) anyway I took it for a REAL drive today (around my backstreets) and OMG does this thing farking scream and kick when it's wound up on boost. Have not stoped smiling all day... can't wait to get it on the dyno for a tune and atwkw reading, then down to Calder :D
dude, don't wind up the boost on the car until you've had a good tune. the car ran on high octane fuel all its life and is NOT used ot the poverty octane rating optimaxes at the pumps here.
Craig rang me n said he was gonna go over to check out the car and you were happy as, I asked him to let me know so I could cruise along too. Good to see you're happy with it. Now come to the meet at the whitehorse on tuesday and join the club beyotch!
PS how'd you jump the car at TOLL didn't you have a jumper pack with you?
Craig still has not come to check the car out yet... come round with him and check it out. Tell him to give me a call when he is ready because I want to get it complied ASAP. I only wound it up a bit... heheheh
I know I should wait for the tune but I was just looking at it all day sitting there. Sounds and feels like it is running solid (now I have the filters on). The clutch is VERY grindy but catches so shap and strong, that is what I need to get used to and the reason I stalled a gizilion times yesterday. My sister drove me down to Laverton and folowed me home...so she gave me the jump start (after running down to the shell and paying $35.00 for jumper leads) When turning onto the Westgate she made it through and I stalled (causing the block) I rang her on my mob and asked her to turn around and save me.
Tuesday @ Whithourse (no GTR) I will probably catch the farkin tram. Membership sign up OK that night?
apparently you're near Craig's office so if you want I can ask one of the boys to give you a lift in, or I can give you a lift if I'm there on the day.
As for membership signup, yeah we'll have forms on tuesday.
Will try to come over when Craig does.
The only thing I will be riding is my woman or my GTR... sorry to disapoint about any other type of ride...
If you boys who live close by want to go on a short squirt SAT or SUN I will be down for that.
It's not going to be that bad this weekrnd.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
