Hey Sk, is there going to be much difference if i use an 85mm throttle body? Or am i actualy better off trying bigger like 100mm?? Im not up with this airflow stuff so please inform me? I wont be racing around a circuit, it will be dily driven on street with occasional willowbank day for drags and drift. no circuit racing. does this make the single tb choice alittle better?
Steve, I have "tried it" both with a standard RB25 throttle body and a Foulcan throttle body.  I could fee lthe slowness instantly on the road, and on the track it was disasterous.  With the dog box we have ~50 milliseconds for a downshift and you MUST match the engine rpm with the gearbox rpm.  Otherwise you end up with twisted splines on the input shaft from the triple plate clutch and missing teeth on the gears, particularly 2nd.
It is quite simple to understand why this is the case.  With the multiple throttles there is very little air between the butterflies and the inlet valves.  So when you close the throttle the airflow to the engine stops instantly, therefore so does its power production.  Compare that to a single throttle body with a plenum in between the butterfly and the valves.  The usual rule of thumb is at least double the engine capacity in the plenum, so on a 3.1 litre that's 6.2 litres.  Plus that 6.2 litres is under boost just before you close the throttle, so at 1.5 bar it really has 9.3 litres of air in it.   In addition, after you close the throttle, the plenum goes under vacuum, around 0.25 bar is not unusual, that's another 1.6 litres.
So when you close and reopen the throttle 7.8 litres of air flow dulls the response.  On a 3.1 litre engine that's almost 5 revolutions of the crankshaft, at 7,500 rpm that's 666 milliseconds.  That's more than 10 times slower than the gearbox will handle.  To translate that into distance, at Bathurst it would mean we would be lapped twice during the race distance
Another way to look at it, Nissan designed the GTR to win races on the circuit, if they thought a single TB was better then they would have used it.  Let's face it, a single TB is simpler to make, therefore cheaper, easier to tune and maintain.  But Nissan went for multiple TB's, why?  Because for their stated aim it was superior.
Let me close off with;
An 85 mm butterfly or a 100 mm butterfly, it makes no difference in the example I have given above. It is the volume of air between the butterfly and the inlet valve that matters. Obviously if the turbo can supply more air than will flow though the buttefly, then bigger is better. But I personally have used a standard RB25 TB and inlet up to 450 bhp and it is certainly not a restriction at that power level. I have seen a Zeni Tani built 550 bhp RB25 with the standard TB and inlet and it did not seem to suffer either.
Regardless of whether it is for road or circuit, as most people know, I hate cars with poor throttle response, turbo cars already have too much for me, even at their best. So I see no reason to make it worse and, if everything else is equal, a single TB WILL make it worse. Well up to a power level that I have yet to exceed anyway.
If you are intending to use a MAP sensor driven ECU (not an AFM driven ECU) then go with the single TB, it makes the tuning so much easier. Multiple TB's and MAP sensors are not happy together.
Hope that answered your question. :)
sorry to be off topic but every post i see from sydneykid is of excellent quality and as others said he is teaching everyone something new :D
keep it up
so also with my rb26 with 6 throttles bodies, and autronics be a problem to tune with more power? (currently got 350hp atw, 12.0 @ 118mph)
cheers
Brad
i will be using a power fc with the single tb. Im alittle worried about the difficulty of adapting the gtr plenum to my rb25 head. Seems port design is different. i have no idea.
Power FC runs AFM's so the multiple throttle bodies would be OK. :D
You didn't really think that Nissan would make it easy to put RB26 (flagship) stuff on an RB25, did you? They simply didn't want the value of GTR's being deminished, so they made it as hard as possible. :headspin:
cheers
Brad
Hi Brad, not a problem for the Autronic, if well tuned of course, they can handle multiple throttle bodies :D
SK? so how hard is it to mount the gtr plenum to a rb25det? (r33 model) what mods would need to be done?
And to add to that, do u know anyone that could mod to fit the rb25 and wat price am i looking at?
SK u have turn me off the greddy plenum and onto the gtr one :D apart from the cost factor, by the sounds it much better :D
SK u have turn me off the greddy plenum and onto the gtr one :D apart from the cost factor, by the sounds it much better ;)
Honestly it is cheaper to buy an RB26 top end and sell the RB25 top end, than it is to fabricate the stuff to make it fit an RB25. Plus you get all of the RB26 advantages, solid followers, valve springs, valves, ports, combustion chamber, squish etc etc. And the other parts, cams pulleys, no VVT etc are much cheaper and easier to get second hand for an RB26 than an RB25.
I have done the numbers 20+ times for people, it always works out cheaper in the long run, you get a better result and it's much easier to sell if you ever want to. :D
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
