To all those who came last time I would sincerely like to thank you all for your excellent behaviour. Now that the first event has been finished we're inviting all drifters, beginers to advanced.....
WHERE: Morwell Hill Climb Circuit
WHEN: 6th November 2004, 9:00 am till 6:00 pm
COST: $75 Track Fee, $25 Annual Membership
Morwell is located about two hours out of Melbourne. The event will receive coverage in magazine (most likely Drift Battle). The track will be available for the whole day with marshals present for safety. Numbers will be strictly limited to ensure maximum track time. $5 per car donation entry for all spectators. All profits will be donated to the Track. There are BP and Mobil servo's with 98 octane locally
There will be a drivers briefing at 10am and is ESSENTIAL for all drivers, if you miss it you don't drive.
Remeber:
1. Two hours drive down and back
2. Can transport all their own spare rims and tires (no fitting available)
3. $50 Deposit required to confirm place
Please e-mail, call me on 0425 818 755, or drop in at XTC to arrange payments.
Doc.
https://www.sau.com.au/forums/topic/51531-xtc-drift-day-morwell-6th-november/
  • 3 weeks later...
  • 3 weeks later...
The $25 covers membership to Gippsland Car Club for drift events only, this allows for the public liability insurance through CAMS.
Safety - There will be extinguishers around the track, but one in your car is highly preferred, helmets are essential.
So if you already have a current CAMS L2S then this is not required?
I'm confused. I thought it either was a CAMS event fully covered by CAMS or wasn't. Either way I will be happy to pay if the event is good.
Is morwell a good place for drifting? I haven't been their before, but I was under the impression that it was a thin track, with tight corners. No much good for big boat GTR's
big boat GTRs arent exactly easy to drift in the first place... ud be better off in ur gem :(
hmmmm if i can scrape the money up for it i might be able to bring the ceffy.
do u have to go thru any scrutineering sam?
if not... will make it much easier :(
In full RWD the R should drift nicely..... check out drift battle issue 3.... I was drifting the white ceffy on the cover... the photo's were taken at morwell so it shoul give you some idea...
Alex might be bringing a tyre machine so that should be all good! will also have a heap of second hand tyres for people to use at a good price.
I am just trying to organise a trailer... i dont wanna risk driving all that way with no rego or plates.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
