Hey Dude,
I have a CA18DET in my Onevia. There is no real downfall for the engines apart form the age. They have a cast iron block.
The stadard turbo is alittle small but with a few simple upgrades the engine is good.
I've reco'd mine with forged pistons and have things like FMIC, GT28, 3" and other basic stuff, I'm about to upgrade AFM and injectors and am expecting 200 rwkw. They are a good engine and react well to boost!
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1030760
I had a ca18 det in a silvia and can't say anything bad about them - in fact I reckon it was faster than my r33 after a few basic mods. Light cars shouldn't be overlooked!
My old R33 was a beast compared to the 180. Have to say that the CA18DET isn't driving to bad at the moment though.
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1037466
Sydneykid had a post going on a while ago about some of the upgrades you can give a CA18DET; they're a tough engine, having an iron block (like RB's).
With a strong crankshaft (~$1800), and probably some nicer valve springs, you could easily wind the rev-limit up a bit more. Or get a stroker crank, and make it a CA'20'DET. Now we'd be torquing.
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1043557
my old strawberry face 180 had a CA18DET that put out 174-178rwkw... its basically the same as an RB20DET engine with 2 less pistons :D very responsive in the lower end. Don't get stupid on the engine trying to poke power out of it (if you need a drift pig you don't really need that much power as you do response, which the CA18DET has when tuned properly) and you should be fine.
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1043564
ca18 is a tuff bit of gear and the only bad thing against this motor is that its a little older now. short stroke desighn (CA18) is a good thing to have in a drift car if you like bouncing your car off the rev limiter as aposed to a SR20 which doesnt like the revs so much but also doesnt need to either.
its a catch 22 but id go the lil CA anyday its a baby 26 in my eyes!
ME:inlove:GTR
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1064968
The CA18DET has got a downfall!
When revved high for extended periods the pressure builds and forces the oil to build up in the head and cannot run down into the sump quick enough! This can be blocked off like in a stock rb26 since the RB25 can have to same issue.. when this happens look out number 4 cylinder!
fixes can be to bore out the return lines from the head, and block one of the supplies!
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1066461
i was wondering if anyone has removed the butterfly from the second inlet valve for each cylinder?
removing that and the shaft that holds them..and bit of a port job... would increase the flow dramatically!!!
oh and could you add a second injector into that valve to run 8 injectors, piggy backed off the same cylinder? seems strange separating them like that!
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1068227
  • 3 weeks later...
I have a 1990 Nissan 200sx (uk) with CA18DET they are good little engine but they have massive problems with big end failure no so much the mains.
Turbo is there second biggest problem little T25 don't last long, cheap upgrade to a S14 T28 normaly does the trick.
Rubbish standard WMIC
(just sold my 48k mile CA and bought a RB20DET (32k miles) much better ) :P
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1095434
I have a CA with only a few bolt on mods and it beats stock SR 20s. I have had it for over a year and havnt had any troubles at all.
Does anyone know where I can get a Apexi Power FC for my CA 18det. Im in Tassie and just wondering if they come pre tuned for the engine? R they hard to install does anyone know. Thanx
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1105995
Apexi Power FC's are easy to install and come with a basic tune.. but for best performance you would need to get them tuned!
you can get em online or from a performance shop.. autobahn have some but ridiculously overpriced..
checkout greenline or Nengun!
https://www.sau.com.au/forums/topic/51852-ca18det-180sx/#findComment-1106002
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
