  • Replies 57
Yer the firewall is off.
I'm behind a router with the ports 6881-6999 open.
As I said its only your tracker that it appears to do it with.. Be buggered if I know.. ;)
Whats this NAT checking disabled bit that is displayed on the stats screen?
Yer who knows.. Computers suck. ;)
I've been fiddling a little tried a few different settings and it just won't connect with a greeny. I've put the modem in to bridge mode, still nothing :D
EDIT: Doesn't matter i've dropped the modem back to its std. PPOA with NAT enabled, sygate firewall on and set the bittornado to use the ports between 6881-6889 with it using its UPnP to automatically forward the required ports. It appears to now be maxing out my upstream. Still no greeny though.
Its a constant connection just not optimal. :D
for green u need someone else to connect to you, which may take a while from when u first jump on.
anyway if ur a seed, then other users with a NAT, if they want the files, will fix their end, so that u can connect to them. only if two users are yellow lighting that they wont be able to connect to each other.
check ur options of ur bt client, and make sure its actually using the ports u have opened. i use azureus
yeah i am. it wouldnt be a problem with the tracker, that nat thing on the tracker is just disabling a nat test it could do (so it doesnt let people with nats connect), nothing more
It appears I may be behind a transparent proxy.
May have to give Node a call and find out for sure as they state they do not use proxy's.
http://btfaq.com/natcheck.pl
This is not reporting my IP address correctly.
The issue I am having only occurs with PHPBT trackers.
The problem has been narrowed down to the use of a PHP tracker and my transparent proxy that internode run. :D
Basically the PHP trackers are unable to sniff out the real IP address.
The other standard trackers are able to sniff this is why I connect everywhere else with a greeny. Until I come across another PHP tracker. ;)
EDIT: Problem found. :D
The PHP tracker Ash is running is on port 80.
hence there is no :6969 in the http://www.ash.veritel.com.au/PHPBTTracker...er/announce.php
If it was running on any port other than 80 it would look like
http://www.ash.veritel.com.au:6969/...er/announce.php
Transparent proxy's work on port 80, this is why no one can connect to me as it is reporting my IP address as the proxy's IP address.
in azureus there is an option to supply ur real ip in the config->server section. check ur client for a similar option, and then supply it ur real ip, and see if that helps.
Ash do you have the GTR manual, not the engine manual and where can i get from if you do
Thanks
BTW....i managed to get the r32 manual(all that i was after) last night Very very slowly.
Edit: No Worries got it all now.....R32 Service manual, R32 Gtr Manual and R32 Wiring digram.
  • 1 month later...
yeah, no-one has it anymore...
Do you know of anywhere else that is hosting it.
I don't have an R33 but I am looking to incorporate the four manuals and make it easier to navigate for everyone.
I am in the process of getting an R34 Manual translated through a friend in Japan.
it would kinda be pointless without the 33 one also.
I'm also chasing a R32 GTS-T manual if anyone has it and is able to host it, I would be able to download it within a day (would only take me 30 mins once I started)
FTP or HTTP prefered. Otherwise I'd have to use dialup (Can't use torrents at work)
Cheers
Chris
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
