  • Replies 57
awesome guys the torrent is up and running!
http://www.ash.veritel.com.au/PHPBTTracker/  <-- Click there for stats
Torrent attached!
PS. Ill have this up on a 10Mbit Mirror ASAP....
Ash.
am i missing something?
that attachment comes down to me as 'clear.gif'. joels works fine but obviously the tracker is down!
It appears the torrentz.net tracker is down at the moment. :)
For the tracker (torrentz.net) to work you will need to be registered and have your IP address updated (which is done by simply logging on).
When I start the torrent up for seeding or downloading it won't work until I have logged on to the torrentz web site.
Strange I know but thats apparently the way it works with this PIPE torrent stuff.
Well I think.. :mad:
sorry everything just went over my head, so how do i download this in english please, sorry.
Hi John,
First go
here and download BitSpirit v2.6 Final.
The download the latest attached file. Click on "new job" at the top left corner of "Bitspirit" then browse for the file u just extracted from the attachment. Then click OK and hopefully away u go.
A quick web search will reveal sites where u can DL torrents. Sometimes u have to add the .torrent extension to the file.
Hopefully I've made sense and helped u?
attachment working for me now. ive got most of the manuals (only missing r32 and s14) so ill jump on and help out
btw a lot of you dont have ur ports open. if ur using the default settings, u need to open port 6881 on ur router/firewall and forward it to ur ip. otherwise u cant connect to any other users with ports closed.
if everyone had ports closed u wouldnt be able to connect to anyone at all.
Newkleer,
For some reason i have all sorts of trouble getting a decent connection to his tracker.
It stays a constant yellow light.
All ports are open and only last night pulled down a video at 164kb/s.
This is the only tracker that it plays up on. Maybe he is behind a proxy?
Internode (who i am with) doesn't use proxy's.
EDIT: I've just jumped back on as a seeder. The most you will get from me is around 27kb/s. Doesn't look like it with this darn yellow light but ;)
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
