hey all, what is the plug in the centre console at the back under the cup holders? the 2 pronged thingo that looks like a japanese socket.... i am HOPING there is an inverter in the car and its 240 volts. :D
correct me if i am wrong but isnt japan 110 volts not 240?
https://www.sau.com.au/forums/topic/52035-the-plug/#findComment-1026861
I vaguely recall flicking thru the list of optional bits for the Stagea in FAST and an inverter was one of the options. The outlet I think was shown as somewhere in the centre console.
The ouput voltage will be somewhere between 100 - 120V @ 60Hz.
A lot of electronic gear will accept 100 - 240V inputs, so if you want to run something in there check the spec label on the device for the allowable input voltage range.
https://www.sau.com.au/forums/topic/52035-the-plug/#findComment-1028261
not yeat available to the public still working out the details but i ultimately want to provide a site where we can list DIY mods with pics and some detailed model information in english so everyone an understand it.
any contributiuons would be muchly appreciated
will let everyone know when its available
:P
https://www.sau.com.au/forums/topic/52035-the-plug/#findComment-1028985
mcnamg - I am part of the way through setting up the SAU stagea info section - if you want to merge these 2 send me an email. maybe if we set up an sau one you could admin it? It would be like stagea.skylinesaustralia.com or something.
https://www.sau.com.au/forums/topic/52035-the-plug/#findComment-1029631
Christian, is StageasAustralia.com taken? If not, would this cost money to get the doamin name registered? (Not too sure of this stuff myself, as I've never even bothered to use the allocated space given by my ISP, let alone set up a whole separate site.)
Nick T
https://www.sau.com.au/forums/topic/52035-the-plug/#findComment-1029649
Hey Nick.
Stageasaustralia.com IS taken :D - i have emailed the contact about it. I have, however, registered stageasaustralia.net, cefirosaustralia.com & .net - they just point here at the moment.
Christian
https://www.sau.com.au/forums/topic/52035-the-plug/#findComment-1032221
Hey Nick.
Stageasaustralia.com IS taken :rofl: - i have emailed the contact about it.
Christian
Hehehehe. It's not you burkey22, is it?
If not, I'll bet there's a good chance that they'll try and skin you for everything they can get so you can use it too...
Oh well, them's the breaks, hey? At least you got the .net one
Nick T
https://www.sau.com.au/forums/topic/52035-the-plug/#findComment-1032511
Sorry burkey22, I meant to say mcnamg, because he said he's building a Stagea site, but seeing as he already said it's probably an importer, which pretty much rules him out too!
Seems I jumped the gun there and didn't read the previous posts properly. :slap:
Nick T
https://www.sau.com.au/forums/topic/52035-the-plug/#findComment-1033820
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
