I've seen the ones whereby it locks the brake together with the clutch pedal......something else for them to cut.....
which means more time involved,keep a wheel clamp in the car just in case,or 4....lock up all four wheels... :)
add that to the alarm siren hooked up to your airhorns......an internal siren to make him to deaf....Autolok the steering wheel.....or remove it if you have a Nardi wheel....I used to do that.....I'm a paranoid kunt :uh-huh:
  • Replies 58
Where do you buy all these security gadgets?
if you use a steering lock (as I do), make sure you install it on the other side of the steering wheel - theives then can't pull it off towards then when they sit in the drivers seat.
I also carry a length of high tensile chain and padlocks, if I am leaving my car for an extended period, I chain it around the rear sub frame and a steel post/telegraph pole. extreme I know, but try to tow that!!!
SICK .. freaking SICK COUNT!
I am now seriously considering a quiktrak this weekend - I would like to know their financial status however.
Me care about my car too, so you got to spend big on your alarm, plus you always do it right the first time. Brant nemesis isnt a bad buy, pretty good alarm system and never had troubles with it. 6 point imoboliser and keypad start.
I however do like the idea of the chain to a pole idea ;)
One of the features he asked for was the Automatic windows. How much does a system cost that when u alarm your car your windows go up by themselves, or do you just have to play around with the wires?
Thx
Apperantly it's not that much more expensive. It's the time it takes your installer to wire the extra wires up from the alarm to the window relays.
$50 ?
There is a small controller device required so that they only go up a certain amount and stop when they have reached the top. Otherwise you could shorten the lifespan of the power window motors.
This controller is actually a very simple logic device with about $5 worth of parts that people sell for 50-80 dollars retail. Plus labour if you dont fit it yourself.
I believe Brandt fit it for about $125. This is another part of the reason i wont buy another brandt alarm.
This use to be available from the UK. I once enquired over several emails about getting this product delivered to my door from the UK and the legal implications.
At the time they were willing to send it in a box labelled "gift" but were unable to give any guarantee's that it would make it past our customs. I didn't end up buying it.
I also can no longer find the homepage for this item. All I can find now is this or similar:
http://www.bow-gun-hunting-sports.com/autotaz.htm
wil..
I guess it comes down to how bad the thief wants your car. If he wants it bad, whats to stop em using those wheel jack thingoes and just rolling your car onto a tip truck.
Any alarm is (as mentionted) just a time factor thing. If you are serious about not losing your car, id see the only way would be a combination of all the above thigs listed.
Im going for the satellite tracking, and.....YER RIGHT! like im telling the whole of the WORLD!!
Serioulsy though, dont leave gauges, hand controllers, steroes in plain sight. Use a club lock (steering or clutch pedal), a high intensity led, an alarm (maybe the paging type if you want to know asap if your cars being toyed with)
Its all about how long they need to get what they want. If its the whole car, bad luck...:D
I can't get insurance and I do care about my car.
Why can't you get insurance? If someone was to blow up your car then no alarm is going to protect it form that. Trackers sound good but if the theft knew what he was doing wouldn't he disarm it? Trackers sound pretty good though I might get one.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
