Dead stock the car made 115rwkw then with a little bit of fiddling (timing etc) it made 125rwkw.
First Dyno..
152rwkw with 12.5psi & exhaust.
Stock airbox, ECU & IC.
Ran in 3rd gear.. why I don't know.
Second Dyno..
164rwkw with 15psi, exhaust, fmic & bosch910 fuel pump.
Stock airbox & ECU.
Ran in 4th gear..
Also have a run in third gear which made almost the same power (-3rwkw) so gears don't affect the final power output much at all.
In fact a higher gear made more power than the lower gears.
I questioned why and was told in the higher gear the turbo has more time to start pushing some decent air.
Not much more to be had with the poor little old RB20t turbo..
Obviously runs out of efficiency hence not a big gain from 12.5psi -> 15psi.
Tuned ECU and I think it would have cracked 170rwkw easily.
Can someone explain to me why -Joel's- dyno graphs are different in the way that the power curve is. The second graph seems to shoot up faster than the first ?
-Joel- were these runs done in 2 different gears, first run being 3rd a second run being 4th ?
:confused: - Or are these 2 differnt engines ?
They are two different gears as I explained in the post.
I think the biggest reason why the first one looks a little less steep is because the bleeder was probably spiking a little through the mid range and settling on 12.5psi + the lower gear giving the impression it has more mid range.
The second dyno sat on a steady 1bar all the way through the power run and made peak power just over 7000rpm.
Its probably also got a little to do witht he ramp rate or something also as it was wheel spinning when coming on to boost even with a couple of people in the boot (crappy half bald 205's).
Theoretically running a car in different gear will yield a different looking power curve BUT the final power should be basically the same.
It's just the way they are scaled.
Look at the figures on the bottom and side of the graph.
The first one starts goes from 50 to 130 kmh and power is measured from 40 to 168kw.
The second graph is from 70 to 150 kmh and the power is from 70 to 165kw, but the kw axis is stretched.
If you scaled the kmh axis from 60 kmh to 160 kmh on the second graph, it would look like a very fat power curve.
  • 1 month later...
Apex'i PFC
Z32 AFM
GTR injectors
FMIC
Full exhaust
Pod
HKS GT2535
Stainless manifold
11 psi
It does'nt have the power because of low boost.
- Red lines are on 11psi with no boost controller conected.
- Green lines are with the shitty Turbo Smart boost controller connected and set at 16psi.As you can see boost is all over the place.
I hope to have 300rwhp once boost is turned up.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
