inark - what on earth are you doing to the ceffy !!!
  • Replies 64
lol yes im selling it :)
infact its pretty much sold...
im going to bring in something cheap to drift in rather than start learning in something with huge up keep costs... its a nice car all be it a drift pig... bu i have my eye on a few things that would be better suited to my needs that are cheaper to fix like an SR powered 32... CA powered onevia and a SR powered S13 with a HKS GT-SS.
Havent taken a deposit as yet but unless someone comes up with a better deal than 17k and a deposit then its sold.
lol no im impatient and smart... this way i clear some debt as well as get a decent drifter... have u seen the 32 im looking at on the jspec site???
unless u wanna sponsor me denham its gone :)
gees denham can u come up with anything new?
u still cant get over cut and paste can u?
anyways... yeah sam thats pretty much it.
id rather sort my finances before i go head first into drifting as a full time pass time/hobby.
if things go wrong its going to be expensive and at the moment i cant afford for things to go wrong. But once this is out the way i can fix the other cars and get rid of them and then i can start again... but in a less debt rendering manor :)
at the time it was ok... but like i said a while ago something came up which i wasnt expecting. But thats now almost sorted but to get it fully sorted im going to have to get rid of it... just bad timing.
damn - inark almost sounds like he is using a level head here.. whats going on :)
sounds like he wants a track car to actually *use* and not look at, and rb26 aren't cheap (or some would say the most reliable -> gasp)
sr powered r32 would rock.. go beat horus will ya :D
I reccon your making the right choice nark. 32's are the shizzle my nizzle, not that i'm biased. Not to happy about the sr in one, but i do see the plus side of having it in a 32. Oh but if you put a piece of Sh1t ca..............in i'll kill you. no joke........i'll find you and knife you down..........:) :jk: Or am i?
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
