Depends on the wheel size...
if its the 8cm then i believe its the 550hp turbo, and the 10cm 600+hp turbo.
I dont think it would be to laggy - on the 6 cylinder 2.5 it should start spooling early 3000 and hit full boost by about 4500.
I have seen one (10cm) on a 2.2 Jun motor wrx and it was on full boost by 4800/5000. So the bigger capacity and extra cylinders should bring it on earlier than that.....
Daniel
I have the neo motor in my r33 aswell, and am looking at getting a TD06-25G (would the smaller exhaust housing make it come on boost slightly earlier?) aswell, though the only bad point is i dont want boost to come one heart beat style, i'd rahter something more linear as far as power delivery, maybe a GT2835 or something would be the better go for a smoother power delivery rather that te punch a td06 will deliver. Another question, what exhaust flange does the trust turbo come with? And with the TD06 whats the best boost to run it, my neo has stock internals, so i was thinking of runnning say 14psi tops, would that be enough to get the turbo working ok?
Cheers.
the td06 range uses a 3 bolts flange pattern which requires the trust manifold or athe flange to be modified on other manifolds, i have seen some mix's with t3/t4 flanges. The td06 is very harsh in its power delivery yes but if u can get the traction it would be awesome, between 1-1.2 bar would be fine
  • 1 month later...
HAs anyone got some dyno charts of their TD06s. Ive heard a few ppl comment on how thye hit boost hard.
I am running a 10cm housing, and would like to go to a 8cm housing, bu tot if the result is going to be a light switdh transition onto boost.
So do they really come on boost that hard, when used with the recommended A/R exhaust housing?
roy. do you think you will lose much power by dropping to a 8cm exhaust housing. although my tdo6 is internal gate it is 8cm i should be putting it on in a couple of weeks.. gonna have exhaust, fmic, fuel pump and a adj reg until i save for injectors maybe microtech or even remap the ecu depends how things go. will let u know how i go.
I doubt id lose power actually. A tuner said i may be able to get away with a more aggressive tune asi have less back pressure so less propensity for detonation...but i dont know if that sounds right in practice?!?!
I would like to try an 8cm, but not if it means wheelspin thru 2md. At the moment with even 1.3bar and what i guess is about 225-235 rwkws i got great traction in 2nd:)
mine is internally gated.. so they do come that way.. they have a stupid wastegate setup tho.. bit hard to explain but not like a seperate flap next to the actual exhaust wheel.. still the same but the extra flap is hidden and.. yea bit to hard to explain. in a way its harder to run the screamer :cheers:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
