that original thread was unfortunate when you consider 2 ppl died in an r33 down here in melb yesterday.
I hope those that posted that speeding like that isnt bad think about how they would feel if they killed 2 close mates.....
https://www.sau.com.au/forums/topic/52910-70-in-a-70-zone/#findComment-1041038
they werent speeding...
it was a wet road with a bend..
i know the honda driver and he's in a very seriuz depression stage..
the two got killed were his best mates..
https://www.sau.com.au/forums/topic/52910-70-in-a-70-zone/#findComment-1041794
:rolleyes:
You know you want one! ;)
You know Dino, the funniest thing is, I am the proud new owner of a white 95 Bluebird SSS. Ahh the comfort of soft suspension, the quite exhaust, the available low down torque, 15 inch wheels. I am a happy man.
Let the blasting begin ladies.
https://www.sau.com.au/forums/topic/52910-70-in-a-70-zone/#findComment-1042646
for gods sake TELL ME ITS A TURBO!!!!!!
PLEASE?!?!
https://www.sau.com.au/forums/topic/52910-70-in-a-70-zone/#findComment-1042679
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
