Ok, so I'm bored at work.
I called up their customer service line 1300 134 555 option 3 then 1. Basically they couldn't tell me much.
Optimax apparently comes from only one refinery. The newport refinery. I tried to bait them into saying that there were either issues at the refinery, or issues with delivery. They didn't take the bait.
Ah well, that was fun. It relieved the boredom of work for a few minutes. :D
wil..
every where I have been today has been good, castlhill,baulkham hills, west ryde.. they all got around $1.12-$1.00..havent filled up for a while.. my car seemed gratefull afterwards lol :D
This is the reply I got from Shell Australia today via email
Dear Edward,
Thank you for contacting Shell Australia.
In relation to your enquiry, the shortage of fuels recently has been caused by an unscheduled maintenance  shutdown at our Newport tank terminal. This has caused severe shortages of all  fuels.
The plant is now back on stream, however we anticipate it will take a few more days for  our drivers to  complete the back log of deliveries to  sites.
It may be that some sites run out of product before the tankers can get back to them.
We apologise sincerely for the inconvenience this has caused. Please be assured our plant managers and drivers are working around the clock to ensure  consistency of supply as best they are able.
I trust this has been of assistance to you.
Regards
Patricia O'Reilly
Tell Shell Australia
PH: 1300 134 555
Well their is two places (in the World) were they cant sell Optimax and I found out WA is one of them, we only use Ultimate from BP over here, when I lived in Newcastle we always used Mobil's Premium as it is 98.8 to 98.9 (I drove tankers for 6 years and ran a fuel storage area so I learnt a bit about fuel).
One of the Japanese motorcycle builders told buyiers not to use Optimax in one of their up market bikes.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
