Hi guys,
I've seen some skylines around with what I assume to be "Locked Diffs" they make this skipping noise of the inside wheel while turning tight corners.....
... first of all, is this safe for daily driving ?
Does anyone here recommend a locked diff brand/type ? Are there switchable diffs to lock/unlock them ?
What's wrong with the standard LSD that comes with Skylines ? Or was it an option?
And what exactly is an active LSD ?
Are you able to lock a standard skyline diff ?
I have Active LSD on my R33 SII GTS-25T and this is what I know about it and it aint much.
The Active-LSD uses a computer to sense wheel slipage and diverts power to the aposing wheel rather than by mechanical methods, the main difference is the speed that is can tranfer power from wheel to wheel. 1/50 sec. It uses a similar system to the 4WD system on the GTR but only transfers power from side to side.
I've got a mechanical in mine and your right, they are a bit noisey around tight slow corners. But apparently they give you the best grip for a (two wheel drive) rwd car.
Straight line drags are great, corners are a bit strange at first, but once you realise that they are very pradictable your OK.
They really aren't as bad as everyone says they are in the wet either.
J
Originally posted by tlai909
Do all Skyline r33 models have the basic mechanical LSD?
T.
All turbo R33's have LSD as standard. But mechanical locking LSD's are an after market thing.
Some loucky people got the Active LSD's, they are again different to normal LSD and mechanical locking LSD's.
Sooooooo many diff's.........
J
  • 6 months later...
I'm looking at getting a manual r33 sedan still deciding on turbo or not.
so does that mean a turbo sedan will have a viscous LSD and a non turbo wont have LSD?
can someone clear it up for me please.
Yeah, standard diff is viscous.
Viscous diff uses property of the oil to limit slip - as slip occurs it get stickier. quickly.
The active diffs use sensors on the wheels, and electronically controlled clutches to control torque - just like the front to rear split in atessa.
with the mechanical... so it locks under power ?
That sounds good... The wet wouldn't bother me as my car is nasty as it is so i take it easy.
But it can be a little unpredicatble at times, so J, if as you said it makes it more predictable ?? Then i would want that.
And that's good for drifiting isn't it ? That's what i'm aiming for over the next 2-3 years as a project!
R31 - yepp, you've hit the nail on the head. From my limited experience (cause I drive like a granpa most the time!), when the back comes around it's very predictable.
From what I've read, the mechanicals are great for drags and trackwork, and even better for drift. They can be a bit noisey for street driving. Some days it pi$$es me off, but other days I think 'damn I love this diff !!'
Like last night overtaking someone doing 70 in a 80 zone... Raining... I drop it back to 3rd and give it 1/2 throttle. It starts spinning the wheels but it still holds a dead straight line.... Unless you flick the wheel a bit of course :)
Meg's - does your's clunk (inside wheel skip) around tight corners when you give it a bit of throttle?
GaryD - Mechanicals only lock up when the throttle is pressed, so they are sort of open wheeler diffs until you give it some go.
The reason why they are good for track work is cause instead of pulling hard out of corner from just before the apex and spinning the inside wheel (typical for even LSD diffs) they will power around with both wheels with a bit of oversteer.
But the oversteer isn't massive and is very easily controlled. Infact most, if not all V8 supercars use either locked or mechanical lockers of some sort.
I was up at Wakefield last friday watching the Brute Utes have a pratice, and as they were coming into the workshop area all of them were skipping the inside wheel while turning tight and slow....
J
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
