Hey guys, i got my suspension i ordered through nengun today, the TEIN type wagon. only problem was when i opened the box, there were only 3 shock absorbers, the 2 fronts and only 1 rear.
I think this is a funny sort of suspension kit, considering what i paid for it.
as soon as they send me the other shock absorber i'll let you guys know how it fits, for now here's a pic of the 3 i have.
Post up the measurements (wire ID, coil ID and the number of coils) and I will work out the spring rate for you:cheers:
Well Nengun say they sent the 4th shock in a previous package, but with the same EMS number. My post office said they haven't received another package with that number, so idon't know where it is. hopefully it'll show up somewhere, it has my name and address on it, that should help it find me.
So they sent a single shocky first by itself, then sent 3 more... LOL - wtf??
Posted this elsewhere but should probably go in the suspension thread for people looking only in here for supension options...
Here's an dam expensive choice at $3700 - but very noice being PentRoof Bilstein WGNC34 specific coil-overs :D
order online from: http://www.ab-flug.co.jp/indexf.htm
(and shout me a set while you're at it)
Here's an dam expensive choice at $3700 - but very noice being PentRoof Bilstein WGNC34 specific coil-overs :cheers:
They won't fit a Stagea (non 260RS), they have forks at the bottom of the rear shocks, Stagea rear shocks have eyes at the bottom. They are GTR shocks I would say.:)
Awww - dammit
Thanks SK... spoilsport
Do all the parts on my other thread look like 260RS only parts SK??
Cheers
They state 7/6 which is 7 kg / mm (390 lbs per inch) for the front and 6 kg / mm for the rear (335 lbs per inch).  As a comparison, the standard Stagea fronts are 165 lbs per inch, so that's a 137% increase in spring rate.  Usually for sporty road use I would be loooking for around 30% increase.  I think I'll leave it at that, you can make your own judgement from the numbers:cheers:
Call me stupid SK - but I cant get my head around this - didnt really think about it when you did this reply above, but...
If 7/6 is around a 137% increase and way too hard, and 30% increase is ideal ... arent the Tein S Tech springs ok, being 3.1 Front (172pounds/inch or 4% increase over stock) and 3.8 Rear (213pnds/inch or 25% over stock).
The Tein S Tech lowering springs would end up under the 30% max you recommended, with 25% increase at the rear, and pretty much same stiffness at front with only a 4% increase.... but you have said before the Tein spring are way too stiff.... am I still missing something in all this suspension mumbo jumbo??? :confused:
Cheers
Hello all (esp SK)
Time to replace the radius rod bushes on the stag. Do I go factory or
do I go whiteline ?? if they have them
And while I'm at it, should I get a more "adjustable" setup in the radius
rod setup ??
Any hints clues would be appreciated
cheers all, and thanks, this is a great forum !!
Cheers
Nope, you got it right, if the Tein S Tech are truly 3.1/3.8. Maybe they started to listen to the rest of the world. Then it's down to what shock valving rates they are using.
Hello all (esp SK)
rod setup ??
Stageas (like GTR's) need more caster real bad, so I would always go for the adjustable Whiteline replacement bushes. Being 4wd, we can't get as much caster on them as GTST's, but every little bit helps.
Looking for some input guys (esp SK).
Getting the radius rods replaced (bushes are shot) on Wed, and the guy said I can have the adjustable versions if I want. Is this a better option than the whiteline bushes (both will give caster adjustment ??). Or do I completely misunderstand
the Stagea front suspension ?
thanks and cheers
thanks and cheers
Previous post on this subject......
In order to increase the caster you simply pull the front wheels forward in the guards. Not enough to rub though. This changes the front steering toe angles and therefore you need to re-align it after fitting and adjusting the caster.
If the caster rods you are looking at have spherical joints at the front (not polyurethane or rubber) then you will notice a slight increase in NVH as there is no dampening. Sphericals also wear rapidly on Australian (rough) roads, and they then knock noticeably.
Since they don't have as much "play" as a polyurethane bush they do provide more constant caster settings (less flex) but that comes at the price as above ie; as usual, you don't get something for nothing.
As you can tell, I am not a fan of sphericals in a road car, they wear out very fast in that environment, knock like a bustard and cost as much as a new arm to replace. Plus they add quite a bit to the NVH (noise, vibration & harshness) even when new. Consequently I would always recommend an adjustable polyurethane bush.
:rofl:
SK, your'e a legend, thanks heaps for the info.
Just to let people know, i'm getting my TEIN Type wagon coil overs and whiteline sway bars installed tomorrow, i'll get some pics up once i get her home. i don't have time or tools to do it myself, which is a bummer because this thread is super helpful.
anywho, just letting people know if they're interested
Cool, it'll be good to see how it goes. Once done you'll be able to out handle most cars :D
I've been tempted to get a set of sway bars, but I know if i get them then I'll want new suspension and then do the camber and next thing i know I'll get a loan and do a rb26 and 5 speed converstion.. lol
Well got my car back from Inline. he says the springs have to settle before he can lower it at all, but the sway bars are in and work absolutely awesome. the car takes corners like it wasn't even trying, and there's barely any body roll. all in all a good investment in my opinion.
The Bilsteins go in this weekend, so I measured the centre of wheel to guard heights as it is now;
RHS Front 395mm
RHS Rear 370 mm
LHS Front 395mm
LHS Rear 372 mm
I am thinking of around 360 rear and 370 front, so I will have to machine some extra circlip grooves.  Maybe 6  at  5mm intervals.
Need some feedback from the guys that have already lowered theirs, please post up your centre of wheel to guard heights...........:cheers:
SK,
I realise this is an old post but have just measured the S2, and the figures are:
RHF 360mm,
LHF 360mm,
RHR 365mm, and
LHR 372mm.
However I have a weeping shock on LHR so may be this is having an impact on height.
The vehicle has NISMO springs but have no idea as to what the specs are.
Marc2
SK,
RHF 360mm,
LHF 360mm,
RHR 365mm, and
LHR 372mm.
Marc2
Thanks Marc, looks like the usual 30 mm lowering on the front, but with standard height rear. I did similar with ours, it takes away that nose up look they have when the rear springs settle due to load carrying. The diff right/left rear is usually because they spend a lot of their life with just the driver in the car. If you are changing shocks it may pay to check the free height of the springs and maybe swap left to right.:cheers:
PS; send me the spring specs and I can rate them if you like, using the computer spring rate simulator, it is very accurate. I would need the wire diameter, coil ID and number of coils.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
