  • 1 month later...
I have put together a list of parts I’m planing to get to sort my car out, all from Whiteline. What I have listed is essentially all from the R33 GTR kit minus the rear Shocks and Springs. The rear shocks are R33GTS Bilsteins. But I have been unable to find a spring to mach. Using the GTR front spring and shock combo will give a hight of 355mm and I would like to aim for a rear hight of 360.
Has any one worked out what rear spring is suitable and if so what the part number is?
Dose any one know what the weight is of the Whiteline GTR front spring 83159?
The stock springs are Front 165 lbs per inch and Rear 170 lbs per inch giving the rear 8.25%. heavier weight. I would assume it would be a good idea to aim for a rear spring that is the same % heavier than the Whiteline GTR front spring as with the stock springs.
Alignment settings
Front toe 0
Rear toe 0.5
Front camber 2 Negative
Front caster L 5.5
Front caster R 5
Rear camber 1 Negative
Front Height 355
Rear Height 360
Alignment Bushes Part Number Price
Front Caster adj KCA332 $120.73
Front Camber adj kit KCA348 $163.55
Rear Camber adj kit KCA347 $136.36
Sway Bars
Fronts - adjustable whiteline BNF27Z $213.64
Rear - adjustable whiteline BNR11XZ $241.82
Shocks
Front Bilstein 120370 $308.18
Rears Bilstein 120110 $261.27
Springs
Front Stock 165 lbs per inch Whiteline 83159 $158.18
Rear Stock 170 lbs per inch Aftermarket ? $158.18
Total $1,761.91
With GST $1,938.10
Alignment settings
Front toe 0
Rear toe  0.5
Front caster L 5.5
Front caster R  5
Front Height 355
Rear Height  360
Sway Bars
Shocks
Springs
Total                                                     $1,761.91
With GST                                                     $1,938.10
Hi Burns, I have found the standard spring rates to be a pretty good compromise between ride comfort, load carrying and handling. With the multiple circlips on the Bilsteins I have found a good height. I could go lower, but I have loads to carry and race cars to tow. The stabiliser bars control the roll perfectly and the Bisteins have added the necessary bump and rebound valving so that it no longer feels floaty.
I could design a rear spring rate pretty easily and have a set made, but the standard Stagea spring rate is already pretty high. So I don't think there is that much to be gained. Certainly there would be very little, if any, handling gain on the roads we have to drive on.
Comments on the settings;
Caster is good, more caster is better, wind on as much as you can get.
Toe settings are fine, that's what I have used on ours.
I think the front camber may be a bit high at 2 degrees negative, you will find with the stabiliser bars that it won't roll anywhere near as much and there is not the need for that much camber. Around 1 degree works great on ours, with good tyre wear.
The 1 degree negative on the rear, may be OK, it depends on whether you carry loads or passengers regularly. They do camber up pretty quickly when you load them up, I have found 0.5 degree to be a good mid point, good for when there is just one person and OK for when it is loaded with 4 guys and their gear.
As for prices, I do get 15% discount from Whiteline, so let me know (via PM) if you want me to get anything for you.
:rant:
PS; we are down at Sandown, racing on July 22/23/24. I can bring stuff down with me if you want.
Thanks SK good points on the alignment I based my settings on what Whitline recommend for a GTR fitted with their kit. I would probably stick with the stock springs as you have only problem is I don’t have them. My car came with a set of Teni pogo sticks. I have a full whiteline kit in my Skyline and find the spring weights very good so I am thinking I may as well get some new slightly stiffer springs while I'm at it rather than trying to find a set of stock springs.
I have a spare set of standard Stagea rears if you want them. They would be OK with the Whiteline GTR fronts.;)
I might take you up on that offer. What do you want for them? The prices I listed are the recommended retail prices off their web site, I should be able to get them down on that a bit but if not a 15% discount through you sounds good.
The diary is free on the 23/24th so I will probably drop down to Sandown to say hello and give you a hand if needed even if you’re not bringing stuff down for me.
Well, i have gone and purchased whiteline swaybars. I went into autobarn and the guy said he can do them each at 200, so i got the pair for 400. They should be in store in probably about 1 week, so ill update everyone how they go when i install them :)
anyone know if tein 33 gtr rear coilovers will fit in length compared to a set of tein hr stagea 260rs coilovers?
i need coilovers asap and wondering if the r33 gtr ones will fit mine or are they a little shorter in the rear? :confused:
cheers
Brad
If you have a RS Four V then the mount on the hubs are different. If you have a RS260 then they will fit. For the RS Four V, 33gtst rear shocks will fit perfect, so any variant of coil over for 33 gtst will suit. For the front you need 32 GTR shocks, so any variant of coil over there will be fine. If you look around on ebay and the like you can sometimes pick up stagea specific ones. The E-bay japan is one of the best. Only problem is you will usually need to know someone in japan to have them sent to them, and then get them to forward tham onto you.
Cheers
Gary
cheers mate, well ive got the rs four with a gtr diff in it now, so therfore gtr style fork ends on coilovers, so i need either 260rs ones or gtr? and whats the difference up the top? can i modify 260rs ones to fit mine?
any pics jake32 :P
cheers
Brad
I think the rs 260 ones will go straight in but the GTR ones are different tops. They are bigger than the stagea towers. I have been told you can modify the tops to fit, the bolt holes are apparantly the same it's just the diameter of the top spring retainer that is different. If you can get RS 260 ones that is probably the way i would go, better chance of fitting straight in. In fact i know they will cause that is what we did to get the diameters. I took the measurements of a mates RS 260 struts.
Hope that helps
Cheers
Gary
The Stagea rear springs are parrallel (75 mm ID top and bottom) and the R33GTR rear springs are conical (110 mm top and 75 mm bottom). This makes the strut towers smaller in the Stagea so you get more load space, well that's what I reckon Nissan did it for:cheers:
  • Like 1
hmm, awesome info guys, I bought Espelir springs (60mm lower rear, 40mm lower front) but now i need shocks, so '33 Gtst rears and '33 GTR fronts is the go? I am just making sure :rolleyes:
Thanks. :P
hmm, awesome info guys, I bought Espelir springs (60mm lower rear, 40mm lower front) but now i need shocks, so '33 Gtst rears and '33 GTR fronts is the go? I am just making sure :)
Thanks. ;)
That's the go with the shocks.
I am surprised with the 60mm lower rear, 40mm lower front. Ours was 10 mm higher at the front when I got it (measured at the sills), it had that dictinct nose up look. So when I adjusted the height with the circlips I went 15mm lower in the front than the rear. Now it has that slight nose down look that I prefer from all cars.
Personally, I would never consider using springs that are 60mm lower rear, 40mm lower front in a Stagea, ours would have been 30 mm higher at the front than rear. YUKO!!!! I reckon 60mm lower front and 40 mm lower rear would look much better, but the coils are different (conical front, parrallel rear) so you can't swap them over, even if the rates where suitable.
:) cheers :)
hmm, maybe i have it the wrong way around then, its very level.
Out of curiosity, does the GTR/Gtst rule apply also with coilovers? I was reading in this thread that the springs were too wide for the rear of the stagea, but coilovers are more narrow. Anybody know?
Christian
  • 5 weeks later...
Just a question about camber kit
I have a vibration on braking, but no pedal pulsing. My mechanic said
that it may be the upper control arm bushes are worn. I think the camber kit
will replace those the the offset bolt and new nolothane bushes.
Can I kill 2 birds with this one.
cheers
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
