  • 1 month later...
I have put together a list of parts I’m planing to get to sort my car out, all from Whiteline. What I have listed is essentially all from the R33 GTR kit minus the rear Shocks and Springs. The rear shocks are R33GTS Bilsteins. But I have been unable to find a spring to mach. Using the GTR front spring and shock combo will give a hight of 355mm and I would like to aim for a rear hight of 360.
Has any one worked out what rear spring is suitable and if so what the part number is?
Dose any one know what the weight is of the Whiteline GTR front spring 83159?
The stock springs are Front 165 lbs per inch and Rear 170 lbs per inch giving the rear 8.25%. heavier weight. I would assume it would be a good idea to aim for a rear spring that is the same % heavier than the Whiteline GTR front spring as with the stock springs.
Alignment settings
Front toe 0
Rear toe 0.5
Front camber 2 Negative
Front caster L 5.5
Front caster R 5
Rear camber 1 Negative
Front Height 355
Rear Height 360
Alignment Bushes Part Number Price
Front Caster adj KCA332 $120.73
Front Camber adj kit KCA348 $163.55
Rear Camber adj kit KCA347 $136.36
Sway Bars
Fronts - adjustable whiteline BNF27Z $213.64
Rear - adjustable whiteline BNR11XZ $241.82
Shocks
Front Bilstein 120370 $308.18
Rears Bilstein 120110 $261.27
Springs
Front Stock 165 lbs per inch Whiteline 83159 $158.18
Rear Stock 170 lbs per inch Aftermarket ? $158.18
Total $1,761.91
With GST $1,938.10
Alignment settings
Front toe 0
Rear toe  0.5
Front caster L 5.5
Front caster R  5
Front Height 355
Rear Height  360
Sway Bars
Shocks
Springs
Total                                                     $1,761.91
With GST                                                     $1,938.10
Hi Burns, I have found the standard spring rates to be a pretty good compromise between ride comfort, load carrying and handling. With the multiple circlips on the Bilsteins I have found a good height. I could go lower, but I have loads to carry and race cars to tow. The stabiliser bars control the roll perfectly and the Bisteins have added the necessary bump and rebound valving so that it no longer feels floaty.
I could design a rear spring rate pretty easily and have a set made, but the standard Stagea spring rate is already pretty high. So I don't think there is that much to be gained. Certainly there would be very little, if any, handling gain on the roads we have to drive on.
Comments on the settings;
Caster is good, more caster is better, wind on as much as you can get.
Toe settings are fine, that's what I have used on ours.
I think the front camber may be a bit high at 2 degrees negative, you will find with the stabiliser bars that it won't roll anywhere near as much and there is not the need for that much camber. Around 1 degree works great on ours, with good tyre wear.
The 1 degree negative on the rear, may be OK, it depends on whether you carry loads or passengers regularly. They do camber up pretty quickly when you load them up, I have found 0.5 degree to be a good mid point, good for when there is just one person and OK for when it is loaded with 4 guys and their gear.
As for prices, I do get 15% discount from Whiteline, so let me know (via PM) if you want me to get anything for you.
:rant:
PS; we are down at Sandown, racing on July 22/23/24. I can bring stuff down with me if you want.
Thanks SK good points on the alignment I based my settings on what Whitline recommend for a GTR fitted with their kit. I would probably stick with the stock springs as you have only problem is I don’t have them. My car came with a set of Teni pogo sticks. I have a full whiteline kit in my Skyline and find the spring weights very good so I am thinking I may as well get some new slightly stiffer springs while I'm at it rather than trying to find a set of stock springs.
I have a spare set of standard Stagea rears if you want them. They would be OK with the Whiteline GTR fronts.;)
I might take you up on that offer. What do you want for them? The prices I listed are the recommended retail prices off their web site, I should be able to get them down on that a bit but if not a 15% discount through you sounds good.
The diary is free on the 23/24th so I will probably drop down to Sandown to say hello and give you a hand if needed even if you’re not bringing stuff down for me.
Well, i have gone and purchased whiteline swaybars. I went into autobarn and the guy said he can do them each at 200, so i got the pair for 400. They should be in store in probably about 1 week, so ill update everyone how they go when i install them :)
anyone know if tein 33 gtr rear coilovers will fit in length compared to a set of tein hr stagea 260rs coilovers?
i need coilovers asap and wondering if the r33 gtr ones will fit mine or are they a little shorter in the rear? :confused:
cheers
Brad
If you have a RS Four V then the mount on the hubs are different. If you have a RS260 then they will fit. For the RS Four V, 33gtst rear shocks will fit perfect, so any variant of coil over for 33 gtst will suit. For the front you need 32 GTR shocks, so any variant of coil over there will be fine. If you look around on ebay and the like you can sometimes pick up stagea specific ones. The E-bay japan is one of the best. Only problem is you will usually need to know someone in japan to have them sent to them, and then get them to forward tham onto you.
Cheers
Gary
cheers mate, well ive got the rs four with a gtr diff in it now, so therfore gtr style fork ends on coilovers, so i need either 260rs ones or gtr? and whats the difference up the top? can i modify 260rs ones to fit mine?
any pics jake32 :P
cheers
Brad
I think the rs 260 ones will go straight in but the GTR ones are different tops. They are bigger than the stagea towers. I have been told you can modify the tops to fit, the bolt holes are apparantly the same it's just the diameter of the top spring retainer that is different. If you can get RS 260 ones that is probably the way i would go, better chance of fitting straight in. In fact i know they will cause that is what we did to get the diameters. I took the measurements of a mates RS 260 struts.
Hope that helps
Cheers
Gary
The Stagea rear springs are parrallel (75 mm ID top and bottom) and the R33GTR rear springs are conical (110 mm top and 75 mm bottom). This makes the strut towers smaller in the Stagea so you get more load space, well that's what I reckon Nissan did it for:cheers:
  • Like 1
hmm, awesome info guys, I bought Espelir springs (60mm lower rear, 40mm lower front) but now i need shocks, so '33 Gtst rears and '33 GTR fronts is the go? I am just making sure :rolleyes:
Thanks. :P
hmm, awesome info guys, I bought Espelir springs (60mm lower rear, 40mm lower front) but now i need shocks, so '33 Gtst rears and '33 GTR fronts is the go? I am just making sure :)
Thanks. ;)
That's the go with the shocks.
I am surprised with the 60mm lower rear, 40mm lower front. Ours was 10 mm higher at the front when I got it (measured at the sills), it had that dictinct nose up look. So when I adjusted the height with the circlips I went 15mm lower in the front than the rear. Now it has that slight nose down look that I prefer from all cars.
Personally, I would never consider using springs that are 60mm lower rear, 40mm lower front in a Stagea, ours would have been 30 mm higher at the front than rear. YUKO!!!! I reckon 60mm lower front and 40 mm lower rear would look much better, but the coils are different (conical front, parrallel rear) so you can't swap them over, even if the rates where suitable.
:) cheers :)
hmm, maybe i have it the wrong way around then, its very level.
Out of curiosity, does the GTR/Gtst rule apply also with coilovers? I was reading in this thread that the springs were too wide for the rear of the stagea, but coilovers are more narrow. Anybody know?
Christian
  • 5 weeks later...
Just a question about camber kit
I have a vibration on braking, but no pedal pulsing. My mechanic said
that it may be the upper control arm bushes are worn. I think the camber kit
will replace those the the offset bolt and new nolothane bushes.
Can I kill 2 birds with this one.
cheers
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
