The geometry of the Stagea rear end is different. The cross member is definitely wider and the drive shafts are longer. I wouldn’t be surprised if the fulcrum points in the rear suspension are different therefore giving different leverage on the springs than in an R33 therefore the different spring rates.
The springs that fit are SK’s secret. You will have to ask him of buy them from him.
Your car looks pretty low in the shot with its Factory 16's! What springs are in it there? Did you have the grooved Bilsteins in at that point?
Got my car back, man it drives straight now. i've always had it pull to the left no matter what my suspension mech does to drive it straight. turns out because the wheel bearings were tired it was pulling to one side. my left front and left rear were shot, and the front right was rusted together. i have the part numbers for the bearings, but i'm too tired to get them from the back of my car. my rear camebr is now set around -0.4 degrees, rather than the -2.5 it was previous. they're just R33 GTSt custom camber arms, i can get the brand but i'm sure as long as you get a good set they'll do the job.
so no more squeeky wheel bearings, no more bad camber. handles like a dream now. pics coming soon.
a camber kit is just a set of bushes with an off-center hole in the middle that you can rotate inside the camber arm joint to adjust it in and out a few mm. an adjustable camber arm replaces the standard arm to allow much greater adjustability
Why would you buy cheap ones over more expensive?
Build quality?
Adjustability?
Different Install?
No difference, just save $$?
So I'll need something like this:
http://cgi.ebay.com.au/R33-ADJUSTABLE-REAR...7QQcmdZViewItem
But I need them for the front.....?
I'll need this because I have been told by two tyre places up here that they are unable to adjust the camber past what it is on my front right, which has crazy negative camber.
BUT Gary indicated that stocker stageas do not have adjustable camber, so I wonder wtf they were "adjusting" and wondering if I do have something adjustable already in there..............?
i paid about $340 for camber arms, and then about $240 for the upper arms, i can't remember the name he gave the upper ones. they're high quality ones, my mech wouldn't put anything less in it. if i wanted cheap ones he said to go do it myself. i'll get the brand of them tonight, he kept the box they came in and it's raining outside so i don't really want to get under the car atm.
What i gathered from the more expensive ones is quality in construction, and durability. bearings in the joints are a big issue, if they're shitty ones they'll break down relatively soon. when you start putting more adjustable joints into suspension you need to increase the quality of the parts so they don't become the weakest link in your suspension setup
pffft there is no I in TEAM!! :P
Yeah whenever you can will be fine, but I will definatly have to get something in there sooner or later.
Ok gyus, here comes part numbers. now don't hold me to it but i might have them around the wrong way.
hub seals: 40323 - 33P55: you'll need these when replacing bearings
front bearing assembly: 40210 - 05U00
rear bearing assembly: 43210 - AA100
the rear assembly is more than just the bearing, it has a mounting bracket with 4 bolt holes as well. i'll post this in the parts list sticky as well
any advance on the brand of the camber and control arms yet?????
as i want to get a set ordered in the next week or so,
it would be nice to know what breed they are and approx cost etc.
There are three ways to adjust camber with the bushes. You can fit two kits in the rear with each kit giving +/-0.75 degrees.
So two kits gives 1.5 degrees adjustment with the stock 0.5 degree thats 2 degrees (thats a lot)
Basically, you just adjust it roughly with the whitelines, then fine tune with the stock adjuster.
Yeah i'm sure it's the wheel bearings. they're shagged completely, making terrible noise and such. i've done almost 170,000km on my stagea. only 2 of them were busted, but i figured i'd replace all of them at the same time.
my odometer might not be accurate either with all the clocks being wound back (got it at 97,000)
As SK said its odd for Skyline bearings to pack up. My R30 has done nearly 600k ks. still got original bearings, seals and boots. The Subaru I just flogged had SIX sets of rear bearings in 120k ks, all supplied by Subaru.
Like Terminals problems they were never ending. I stillhave the R30 and it is because of its excellent service I bought the Stagea.
well i saw them and they were pretty rooted, so maybe my car had a hard life in japan or something. they didn't make any noise when i bought the car, just after i had first used it to tow a trailer.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
