  • 3 weeks later...
I know this is a bit late, but I have read through this topic and am a little confused. Every bilstein part number that someone puts up differs from another persons. Also I have read people saying that rs260 has different rears, the fork kind? My RS4S has the same (I think) so that throws another spanner in the works. Also reading on the bilstein website about the part numbers and the Stagea part numbers are different all together then any R33 numbers. So confused! Also tried getting the part number on the website in but was told they don’t get sold in Australia.
Any clarification would be awesome. Also if anyone has a pic of the fork style and the other style just so I know that I’m not imagining it would be great.
Thanks Guys and Girls.
yes correct RS260 and RS4-S use the same rear shocks, which have a fork at the bottom rather than a 'loop' or eye.
To the best of my knowledge the bilstein shocks have to be ordered through SK, as it is not a stock part, rather a GTR shock that is re-valved to suit the wagon to SK's secret specs. I've got a set of the rear shocks form him sitting in my garage awaiting fitting (been there for over 4 months now).
With reisea's query above in mind...............
Just wondering if your rears have this number on them? These are fitted to my S1 260RS. Have'nt found the number for the fronts yet but in anycase if the custom valving is not recorded by this part number you will still need to contact the guru. (SK)
Cheers GW
I just tried to install the Whiteline swaybars recommended in this thread by SK.
WARNING - The rear bar does not fit. C34 stagea rear is not same as R33 gtst as explained in this thread. It is 2inches too narrow.
The correct rear bar to get is R33 GTR
Hopefully this will save some other poor idiot like me who buys parts based on knowledgeable advice
Thanks :thumbsup: Is that to say (forgive me for not re-reading the entire thread) that a R33 GTR rear swaybar will fit C34 stagea? (RS-Four auto if that makes any difference) because the stagea-specific bars have dropped off the whiteline list and the Selby ones are *very* pricey in my area. But R33 GTR would have a few more options.
Weird question? Cant be ass'd looking thru the whole thing!
Does anyone know what airbag suspension is like to drive with? Thinking of turning my Stagea into a cruiser V.I.P style car... Not sure yet, cops are turd around here.. any jap car they see they pull over and rape them.
Not speaking from experience I should think it would be fine if done properly (but probably illegal in your area).
Just after some ideas/thoughts from you guys.
The front lip of my car was sitting at about 9cm on lowered springs when I purchased the car, I've since had these swapped over for some stock V35 springs and its not at about 13cms in the middle of the front lip. I was hoping I'd get a little more out of them than that, as apparently they're the same spring as a stock M35. My car does have a kit, so that coul well be playing a role, but other than that does anyone know how high the middle of the front lip should be on a stock standard M35?
Does anyone have some experience with the BC Coilover kit ( http://justjap.com/store/product.php?produ...at=0&page=1 ) and know how high I might able to get the front? I dont think I'll be able to get it up my drive way until I hit about 18cm or possibly higher :P I'm going to shoot them an email asking pretty much this anyhow, but thought if I could get some standard numbers of you guys and any learn from your experiences it might make this all happen quicker/smoother :P
Does anyone have some experience with the BC Coilover kit ( http://justjap.com/store/product.php?produ...at=0&page=1 ) and know how high I might able to get the front? I dont think I'll be able to get it up my drive way until I hit about 18cm or possibly higher :) I'm going to shoot them an email asking pretty much this anyhow, but thought if I could get some standard numbers of you guys and any learn from your experiences it might make this all happen quicker/smoother ;)
Hi Dunc, I have them in my nm35, I'm off to bed now :P but I'll post some detail for you in the morning. My car was totally stock suspension before these so I can give you an idea of std ride height.
Cheers, Dale.
Hi guys
I have a 34 stagea RS4.
I've got a really low bar on the front of my car so want to raise the front a bit. I've been given some R34 GT-T standard front and rear shocks. I'm not really worried about the back but want to raise the front. I've gone to put the fronts on but they seem too long to be able to be put on without taking apart the suspension. I've tried using spring compressors but they won't fit on while putting the strut in as its such a tight fit.
Should these shocks fit? It says at the start of the thread the standard ones are the same as the R33 GTR, are they shorter? The ones on there at present have RS+R on the springs are they the standard RS260 struts?
Thanks Scott
Hi Scott, I see it's your first post - welcome!
I assume you mean C34 stagea as I don't know of a m34 model (C34 or M35). The C34 shocks are covered in detail throughout this thread; but basically in summary I am pretty sure the fronts are R33GTR, rears are R33 GTST (but the valving of the rears is *not* suited to the stagea - they just physically fit). One way I can think of to raise it might be to get hold of some Bilstein shocks as they have a circlip-located spring seat which is height adjustable; you can read all about that here http://www.skylinesaustralia.com/forums/St...lin-t85592.html
EDIT: Ah do you have a 260RS? If so then the rear shocks need forks, not eye bolts... see above-mentioned thread for details and have a read through here re. RS260
PS You might actually have to "lengthen" the bump stops lol. Raising the C34 has been discussed before - have a search through this thread.
Edited by DaveB
I can't find any specific mention of R34GT front shocks being tried (it is mentioned however that R34 rears are forks and thus will only fit a manual stag') though the thread is long and I haven't searched much. However SK does make it clear that the valving is all wrong for a wagon with '33/'34 shocks at the front.
Yeah I was trying to look through it all too and that's the only mention of the R34 I could find as well. Looks like its a no go either way. Guess i'll have to source so R33 GTR shocks. Thanks for your help and interest Dave.
  • 3 weeks later...
I already have new Bilstien shocks front and rear, so I guess Im lucky in that respect, and fingers crossed if I ever need new ones I cn match the part numbers.
But I'm thinking of new wheels and lowering it a bit. Have people figured out what is needed for the 260RS front and rear spring replacement? Thinking King Springs or Tein.
Ie, body type/part numbers/and spring rates if needed seeing it is a wagon etc.
Much appreciated :ninja:
If you have Bilsteins you don't need to change your springs. You can adjust the height by moving the circlip up or down. If you have run out of grooves (only likely if you want an extremely low setting) you can get more grooves machined quite cheaply.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
