I'm going to design my own boot floor template so I can make one out of MDF. The factory one doesn't even fit properly! It uses bits of foam to rest on the spare tyre (which I've removed) and the rest of it doesn't appear to line up with any of the ridges in tbe boot.
Before I go ahead and do this though, I just wanted to know if anyone else has done this before? I basically want a snug fit into the indentations around the spare tyre well so it won't move around, and I can then bolt a sub to it (or at least clip it on for easier removal of the 2 separate items). I also want to make it a lot sturdier than the factory cardboard stuff so that it doesn't require the spare tyre to give it stability.
If no one's done it I'll just do my own from scratch and upload the finalised plans for anyone interested.
https://www.sau.com.au/forums/topic/5338-r33-boot-floor-template/
I'll see if I can get some measurements on the weekend, and hopefully buy the MDF too. I'm going to make it as thin as possible while still making it sturdy, because I don't want it coming through the rear seat panel and slicing my passengers in half! :eek1:
I don't think I'll be able to actually make it this weekend though, I still need to find a jigsaw. A friend of mine who had one moved to England recently :D I'll tell you how I go on the weekend.
Well I had a good look the other day and I don't know how this is going to work. There doesn't appear to be any lip around the edge for the floor to sit in.
What I might do is make something with legs on it so that it sits inside the spare tyre well, but I don't know if this is going to work if the spare tyre is in there.
Ah, I just had a brainstorm! Instead of legs to support the whole thing from the bottom of the tyre well, maybe just little bits of wood to keep it in place around the lip of the well to stop it sliding around. Then the actual floor itself can be any shape at all and it shouldn't shift around.
Anyway I'll see what I can figure out eventually.
Yep, as does the factory item. I'm just hoping to design it so that it won't jump around too much and if it does it will land back where it started. Perhaps some foam underneath to help absorb any clunking sounds, or even velcro to hold it down? I could always use nut and bolt type fasteners or clips, but that'd probably mean drilling into the floor of the boot and I definitely don't want to do that.
This is turning into a major project, why couldn't they just design something good from the factory? (sigh)
Hey JimX,
I actually did this on my first R33, Didn't take down measurements of anyting but ;(
I would be planning to do something on mine for a while too :D
What i would do is get the original carpet, put it over a piece of MDF or watever you wanna use, trace around it with a pencil, and then start jigsawing :)
To stop it from boucing i would then goto HARDWARE HOUSE and buy some of that Velcro thats double side..(make sense?) the Velcro was $5.00 a meter i belive.
then stick one side of the Velcro down to the floor and then one on the actual MDF.
As for spare tire issue, i would just get some foam from clark rubber and fill it up to be the same hieght as the rest of floor.
I also wanted to make one for the rear, battery cover thing, pretty str8 forward that one but things is how to mount is.
As i wanted to have my AMP secure on to there.
Let me know how u go,
If i get bored i mite start making one... :)
DOnnie
couple of months back i took out the spare tyre and drove around without it. then i had to do some grocery shopping, buy some drinks and stuff like that. couldn't put it on top! coz the covering that is there is so weak that it just caves in!
so yer, i reckon this thing is a good idea. i'd be interested in it.
i don't think it bounces around that much with the carpet covering it.
I'll vouch for the "tracing around the carpet" idea..
I did this in my sonata to construct a new boot floor. and it works a charm, i user 12mm MDF, sturdy as a rock!
I sunk my amp into the tyre well, flush with perspex and neon's to the floor.
I then had the 2x12's facing the back of the car, pretty much where the flimsy battery cover thinggy is in the Skyline....
Don't forget to secure the MDF to the boot floor. Velco still lets it move around a bit and didnt work for me... I just used countersunk self-tappers, then carpeted over it all in light grey..
looks the sh*t too :)
If your going to use a sub in there, ply wood is ghey, it's too thin and rattles VERY easily...
Good luck guys..
-Kym
I have actually just done this sort of thing in my car.
I basically used the existing carpet as a template to cut the mdf. I stuck 2 seperate pieces with liquid nails onto the corners/sides to act as like a fixed mount. Then I built a hinged 'lid' to allow access to the spare tyre and fixed the hinges to the corners pieces. It seems to work pretty well and once carpeted looks pretty neat.
I know that the corners pieces are now fixed, but the beauty of liquid nails is that it can be broken if needed, but is otherwise pretty sturdy. I aslo used hinges with removable pins so that the lid can also be removed. With the hinged lid setup I also have access to the spare tyre.
It was near impossible to get an exact match up with all the contours, but with the existing carpet you can get it pretty close with the timber, then wack carpet over the top and kinda free cut it so it matches up cleanly.
I chose to use mdf because it is easier to cut than ply and doesn't splinter, which is important because there are a lot of difficult curves to cut with the jigsaw...
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
