Dammit, I never get spotted when I'm out...
BTW, there'll be another Sydney Stagea soon, the car has arrived here and is about to be shipped off for compliancing. The owner has already had a good look through the threads here... It's another white Dayz edition, and will be copping a manual conversion.
nice one, who owns it?
Spotted Fuzzy last night at the angels and airwaves concert, i was gonna come up and say hi but at the time i wasnt sure if it was you, i knew it was you when i saw your stag outside in the street and then i was gonna come up and say hi but i thought id wait for you to drive past but you ended up doing a u-turn so i didnt get a chance.
yeah .. that was me ... hard at work, gotta love being a photographer at times.
You should of come up ... wasnt' like l was really listening to them anyway. I'm at most gigs in melb, so if u see me again .. come up and say hi.
Edited by -FUZZY-
aww yeah i guess i could throw some on. Its very stock, cept for the 17" wheels. Was pretty dirty too... But still, i was excited as hell chasing to catch up to him. Felt like a lil kid.
wow crappy photos... on my phone, at night. Nice guy to talk to, very happy with his purchase, and the attention it brings.
Hey guys,
Im the Jack that Robert was talkin to. Hes the first one i have seen around since i got mine about a month ago. Will get some more pics up soon (when its light). Expect to see me down the coast on the 11th too. Oh, an it'll be washed this time.
Spotted an Autech 260 today. Was looking schmick, have seen it before around the Chermside area. Made me jealous!
That 260 is pretty umm... pretty fat... lol
Seen that in chermy too, though at first i thought it was just a plain S2. Had a few under my belt that night though... lol
Pretty sure i saw this on the highway ages ago though.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
