Just spotted a silver s1 in Winston Hills, near the corner of Langdon Road and Caroline Chisholm Drive. Had "for sale" details all over it...
I spotted this same s1 again today, again in Winston Hills, but near the primary school, so maybe he was picking up the kids - was just before 3pm.
Also spotted a white s2 parked downstairs in the Winston Hills shopping centre, I think it *might* be the same one I've seen parked at the Seven Hills shopping centre, had COP-003 rego plates. I left an SAU-NSW business card on the car.
Spotted RBPOWA at RE Customs as usual :unsure: I think Ray is gonna have to start charging you parking fees :(
if he did , i would be on his back every hour to get it done ! so i dont get a crazy parking bill.
got it back last night at 7pm. might take it back next yr give it a break this year :)
Haha i gotta go back in a week to pick up a few things then i might start saving for an after market ecu, turbo and injectors then go back to get the ecu installed and tuned.
Spotted a pearl white series 2 dayz yesterday arvo on southern cross drive, rego was MAT 878 or something, looked stock apart from lowering, unfortunently
i wasnt in my stagea, i was in my brothers girlfriends mirage....
Spotted another pearl white dayz doing a u-turn on carlton st kensington, very sexy example had intercooler, exhaust, nice rims etc...chick driven.
I was in my dads blue maxima.......dammit everytime a see a stag my one is at home.....bugger
rego was CC. XXXX, butifull stag
spotted on Saturday at around 1.00-1.30 pm: blue M35 heading toward Frenchs Forest on Forest Way (?). I was in Sydney for the weekend... It was good to finally see a M35 on the road: it was the first I've spotted actually moving...
Would have waved, but we were in a '83 Jeep, so didn't bother.
Spotted a silver s1 at around 5pm today at the roundabout where Toongabbie Road and Portia Road in Girraween. I wonder if it's the same one I've seen twice in the past week at Winston Hill.
I beeped and waved, and got a wave in return.
Spotted again: stock grey S1 on Somerset Drive, heading towards Robina Town centre at around 12.45am today. Car had big shiny rims, no rear spoiler, and the stock front bar: young(ish) looking guy was driving. Car was quite neat. Would have waved, but I was on foot...
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
