At last friday's Re Custom's Dyno Day ,met Ryan1600, Infiltrator and The proud owner of WGN C34(sorry I'm bad with names)very happy to meet you all(sorry I had to go away but wife & kid got bored and pissed) How did it go Ryan?Hope to see you around...
spotted this S1 Stag near Mt Coolum on the Sunny Coast
its actually for sale
looked good with no panel damage at all
interior looked alright too
ill go back & get a flyer from the it asap
if anyones interested just pm me & ill have more details
had to use my phone to take pics...
it was good to meet you to,my missus had definitely had enough by the time i left lol,it was good to finally meet a couple of stag owners,although i missed out meeting RBPOWA or ryan1600 though
yeah i got there at 9pm.
my miss's went out with her work mates.
learn boys, dyno nights are for people who can bare it
Ryan was there,he parked next to you(he had a plastered wrist)anyway...did you see his run or infiltrator's?
Sorry i missed youTJ...next time...
Spotted a Silver S2 siting at a red light in the left lane at the Frankston-Cranbourne Rd/Moorooduc Hwy intersection on Monday night (16th Feb).
Gave a wave as I crossed the Hwy in front of you.
Come on, someone must've spotted me by now!!
Nearly 400 km's on the clock :)
400km's?
Jeez, I don't think I have been spotted yet & I have been driving my M35 around Vic for nearly 2 years and over 60,000kms!!!
400km's?
Damn, ok, I'll just quietly drop back into the background :)
People must see it or hear it, Nismo exhaust and manual changing she get's her rev's on lol
Oh there was a spot I made that I havn't posted yet!
Was cruising up Vardy's Road at Kings Park and spotted a white S1 in my review mirror so I slowed up so he could come along side me.
Was an L Plater and the car had different coloured panels here and there, the back end was grey i think from memory.
I gave him a beep and a big blast of 1st gear with high revs :)
I gave him a beep and a big blast of 1st gear with high revs :(
I think that might be the same s1 that my friend told me about last week, with different coloured panels here and there...
121awkw at speed cut, was good to meet you :)
you bastard, i wanted those plates when i bought mine, went to get em but they were gone, bought a FMIC instead haha
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
