canarygsr ! at work with the Nismo LMGT4's and rear bumper thing going on ?
thought that place was shut down, hasnt been cars there for weeks
yeah i just put the autech bar on the back and the sideskirts on the other side to see if i wanted to go with the autech kit or the viva one.. stil abit unsure what i wanna do, ive got one side bare at the moment, i realy dnt know what nisan was thinking releasing the S1 without side skirts, it looks bloody rediculous. got my adjustable camber arms today so yay no more scrapping, ive been driving the statsman to work for the past month or so so that would have been out the front, we rnt there everyday, only a few days a week, had 35,000 Wii's come in today so it was pretty flat out
Edited by canarygsr
haha alright! man you wheels look tough. . . .if im gonna see you car often enough its gonna cost me a fair bit, cause i just have to have them!
i deliberatly drove past ur work twice when i first put then on on the off chance u might see me.. i didnt get a spotted though, i was abit disapointed, haha
Edited by canarygsr
haha which work ? Old dandy road site ? cause if so, where about 50meters below the road atm haha
oh so u would have only heard me then :(.. at the tip to the back of us is a giant mound forming.. trucks all day drive to it and dump dirt on it, it is realy realy big, think they digging a massive hole next to it, im assuming its the next land fil site
yeah that whole is massive ! took them nearly 2 yrs to dig.
that one where finalizing i started that 3yrs ago haha, no EPA wont pass it .... bloody assholes!
you might of seen my daily go past. when your no busy. Maroon Suzuki Ignis SAU stickers for the REP
not sure if this counts, a security guard at Westfield carousel saw my pearl s2 tonight, he gave the :P , i returned it. Also saw a silver r34 with a SAU WA sticker on the side window. Maybe it was his..??
I spotted a gold M35 ARX with a slightly damaged rear bumper (right on the corner on the driver's side) heading towards Horsnby along Pennant Hills Road around 7.45pm tonight.
Spotted RBPOWA at the Pavilion in Dandy tonight i was parked in the back carpark,i think i saw u inside as i was leaving. :D
aye haha, my mate rang me saying whats my car doing there. then i got cravings for some food at that joint. went down, saw no stagea though.
good tucker at that joint!
I was hiding in the back carpark,so kudos to your mate for spotting me hiding in there,and the food was pretty good for sure
forgot that i spotted a white m35 parked under a tree near the bowling club in riverstone last weekend.
There's another m35 in the Redlands? WOW! It concerns me that somebody who owns such a mature car would be at such an immature watering hole.
Bloody "Pit"
