spotted a nice clean white S2 in tasmania while i was on holiday :( nice surprise!
also spotted a white S2 while in federation square last night (8pm?)! past flinders st station and was heading down st kilda road!
Edited by atomaly
saw a white RS4 s nice rims and dark tint, parked at Oporto M4 city bound round 3pm, i went tru drivethru was on my way to work. immaculate!
im from werrington,and often around seven hills, hornsby areas as well. i think i have seen u! look back through this thread and i think i may have seen u at Oporto on M4 once a few weeks back
pg 145 :(
ah yes that was me, i was inside eating, i actually saw you go through drive through, nice car man.
yay, but na i didnt see any other stageas..
Spotted Canarygsr again!
this morning at about 7:45am on Nepean highway right near Centre Dandenong road...
Stuck in traffic mate?
i was going the other way!
yeah traffic is bullshit at that time goin that way.. only had to go to southland so wasnt that bad... didnt see u this time either
spotted a dark coloured M35 AXIS this afternoon around 6.30-6.45 at homebush where ryde road meets concord road. damn nice looking car, that chrome grill looks awesome. older looking guy driving, so im guessing not a member here
Not me but the missus......she's learning!!!!
Her email to me:
Spotted: Dark blue stagea wagon, vehicle registration WYF 219, travelling city bound on Whitehorse road at approximate 7.10am, driven by a male in a fluro yellow t-shirt. Same model 250T - same shape as yours. He also didn't have tinted windows on the front.
If only she realised that the windows are factory like that!!!!!
This was spotted today!
The smart ar*e then sent me another email telling me to tell the cyber world of her spotted Stagea's..... and also that she spotted my car in our driveway at 6:50am same day!
spotted a white s2 heading east on the m4 between northern rd and mamre rd about 4:30 this afternoon
was probably me on my way to tafe its been a while since ive been spotted :D
Edited by Space Goat
spotted a white S2 with front mount next to the bp in southmelbourne near crown, i dont remember too much else cause abit boozed from the races all day but im pretty sure i spoke to u and u said ur name but abit to f**ked to remember....... hope i find u hehe.. it was an RSfour, thats all i remember
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
