yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :blink: its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :P
But I dont think i have been spotted yet!
Spotted a very nice dark blue M35 on it's way up Kariong Mountain at about 2:45pm, I was heading down the mountain and only caught it out the corner of my eye at the last minute. Didn't have time for a flash or a beep.
If you are on the forum hello :P
I know someone at Green Point brought a stag recently but not sure if this is the one.
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :down: its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :)
You sure this spot I made above wasn't you?
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :) its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :D
Don't think it was yours: pretty sure it had factory rims, ánd maybe an exhaust/muffler...
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :P its annoying having a similar stagea to mine so close!
If you were in Manly last night, along the beachfront, then consider yourself SPOTTED!! :)
spotted a white c34 at kings park/kings langley at about 2.30pm today, flashed my lights a few times but I don't think he twigged.
i was on my way down to the shops on a beer run :)
I was up around there over the weekend. If it had ARX wheels it was me.
not sure ive only caught a glimpse of it twice and it was a while ago
once was on medowie rd medowie i was parked and once on honeysuckle it was parked and there was a grey 1 near buy also parked
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
