yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :blink: its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :P
But I dont think i have been spotted yet!
Spotted a very nice dark blue M35 on it's way up Kariong Mountain at about 2:45pm, I was heading down the mountain and only caught it out the corner of my eye at the last minute. Didn't have time for a flash or a beep.
If you are on the forum hello :P
I know someone at Green Point brought a stag recently but not sure if this is the one.
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :down: its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :)
You sure this spot I made above wasn't you?
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :) its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :D
Don't think it was yours: pretty sure it had factory rims, ánd maybe an exhaust/muffler...
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :P its annoying having a similar stagea to mine so close!
If you were in Manly last night, along the beachfront, then consider yourself SPOTTED!! :)
spotted a white c34 at kings park/kings langley at about 2.30pm today, flashed my lights a few times but I don't think he twigged.
i was on my way down to the shops on a beer run :)
I was up around there over the weekend. If it had ARX wheels it was me.
not sure ive only caught a glimpse of it twice and it was a while ago
once was on medowie rd medowie i was parked and once on honeysuckle it was parked and there was a grey 1 near buy also parked
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
