Spotted a Silver m35 on gardeners road Mascot this morning in Sydney at about 930 this morning.
Also got beeped at by KNGM35 on cleveland st around lunch time today, by the the time I realised what was going on it was to late to wave back. Awesome looking m35 mate!
Thanks mate it's been a while since I got spotted
Spotted a white C34, I think it was a S1, with a funny grill. Was in Turramurra about 420pm this arvo. Lady driving.
Grill was like a chrome thing with a "V" in the centre. Never seen it before.
Edit - was a S1 NA grill!
Edited by PN-Mad
that would be right the knuckle draggers!
did anyone spot me up in maitland on the weekend?? plenty of people checked out the car, especially in maccas where there were 983958723548248969584509685734286 commodores in the carpark
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
