Yeah its been going pretty well. Check out www.youtube.com/boscharc.
Good weekend for you guys in the end! Get many k's on the Stag?
Nah, the stag sat in service for most of the weekend, as we also had a triton and a 200 series with trailer so srove around in them.......Yeah I have watched 90% of those vids, good stuff! Berry was a very lucky man in that accident. Sandy is stoked, we didn't have too many major drama's with the cars and winning the SARC is always going to be a good result.
Spotted that silver M35 again on Targo Road in Toongabbie yesterday afternoon, and I've been seeing it there regularly now - it's a stock-looking 250RS, standard 6-spoke wheels, no special custom rego plates or anything.
spotted a black (S2??) at Robina Town Centre, parked on the mezzanine level at around 6.30pm tonight. Had exhaust, lowered and R34 GTR-look wheels and big stickers across the rear window... Anyone on here? Never seen that one before
there was a phat as hell white C34 park on the side walk out front of Jap Link on Parramatta Rd this arvo around 2:00-2:30pm
Ryan (Bodella) and I were both there last night in each of our own cars.
Oh, could it have been the one we had on the Stagea 15th Anniversary cruise, Theo? A white S1 260RS with black TE37 wheels?
i just got mine and live off ballarat road... keep an eye out for a black rs4s
Were you in the City yesterday by any chance?
I saw a very near black Series 2 C34 RS4S on Collins St @ 5:15pm yesterday arvo. I was on a red/white R1 with a mate on a Repsol Blade just in front of it at the lights.
I've been seeing a black RS4 in my street for the last 2+ years ( which is what got my attention to the stag ! ) lowered , black , black rims , nice exhaust , sweet ride ! Oh and randomly I see a yellow s2 c34 not sure what model . Oh lisarow (central coast )
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
