Haven't seen a stagea in months over in Perth, then I see 3 in 24hours. Met Chris (footo) yesterday on a cruise, greenish c34 in doubleview, and silver, maybe an autech?? At the lights,marmion/burns beach road.
I've been thinking of leaving an SAU business card on the car, but everytime I see it I'm either in too much of a hurry to get somewhere or too tired to do it.
You live down Targo or on Targo? I'm on the other side of the station in Toonie, but my car also spends 95% of its home time in the garage.
Clean car? Mine? LOL! :D
Yeh I live on Targo, in a villa near oramzi st. I'm not sure I've seen your car gettin around, is it a dark c34? I've seen a white one getting around nearby a few times and there is a red one owned by an old bloke that I pass near Abbott rd in the mornings a lot but he never waves.
Yep, mine's a dark green s1 C34 with the V35 GT premium 18" wheels on it. I've got relatives who live right up the highway end of Targo Road near the park, and I'm there fairly often.
StageIan lives not far off Darcy Road in Wenty, in a red s2 C34 - probably not the same one you've seen on Abbott Rd.
I've also on occasion seen a silver s1 C34 parked on Targo Road, maybe the owner was going to Tony Shaw's Swimming Pool? Same car has also been spotted in Pendle Hill just off Darcy Road near the Binalong Road end.
Spotted 2 white C34s in Newcastle today. One at about 930am near the stadium heading toward the city. I was heading the other way. And another parked just after as i turned up toward the old hospital at waratah.
I just spotted a silver M35 AXIS on Station Road in Seven Hills about 10mins ago, I was heading the other way in mine.
Also, travelled in convoy with StageIan today to the SAU Picnic and saw Theo and met Craig.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
