Yeah man would have been, I've got a white series two.
Riding my bike up and down hampstead for work this week, so if you see a cyclist waving you down its not some weirdo, well maybe I am but still you'll know. Hahaha
I live on the other side of Toonie station, but have relatives near the Girraween end of Targo Road, so I'm down there fairly often. I also use Targo or Toongabbie Road to get to Unigoup.
Oh really Gav? I've never seen another dark green s1 around here...
Next time I see it & there is no traffic island in the way, I'll hang a Uie & chase him down for a chat!!!
Shit, forgot.
This morning travelled behind a white pm35 with a nismo exhaust, and roof racks or more accurately roof bike racks on.
About 520am through turramurra.
Saw this - again. Same place, same time, differernt direction...
Spotted a very neat black m35 in the St Marys region on Saturday afternoon.
Had similar plates to Iains old car, forming Stagea out of numbers and letters.
Sweet ride whoever it was. :)
Yeh I have been finally spotted by someone other than Theo. Didn't see you? But then again the kids were driving me nuts all morning and my only focus was to get them to Nanas! Lol. Thanks for the compliment! :-)
LOLz.....you wont see Stephen and his gone even more gay than his last pink M35.........Maxima man now!
Yeh....epping rd....spell check got me again....black wheels aye? I honked going in the opposite direction. Second time I've seen your car now!
Spotted your missus(I think) today at about 4.30 on pennant hills rd!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
