Big big big favour -- translation
Hi everyone,
Just wondering if someone can do me a huge favour and have a look at http://www.hks-power.co.jp/products/power_...cluch_data.html and tell me what all the columns are (specifically looking to see if any of the columns is thrust bearing number). Tried to run it through Babelfish but it didnt like it.
Thanks heaps!! :D
https://www.sau.com.au/forums/topic/53505-big-big-big-favour-translation/
Ok, ok... very very quick translation (from left to right):
Make, model number, engine number, year (built), transmission type, actuation type, Clutch series (or name), flywheel weight, clutch type, code number, price (price without tax in brackets), option, and "notes".
Ok? :D
how about this one (for a guy on another forum).
Hey,
I just got a new car.  It going to annoy me forever unless I find out what this stuff says, or what its going on about in general.
Pic number one, this sticker sits just infront of the auto.
Pic number two, this sticker is on the side of the console.
Pic number three, this is underneath the sun visor.  I would just like a general 'jist' of what this one is on about.
Thanks everyone!
pic one..
about a gear shift lock i guess. maybe says when your gonna move push the brake and then use the shifter... dont know the 2 kanji before kudasai though.. __saku.
pic two.
says this car is equipped with a turbo and the oil should be changed every 5000kms or 6 months. also says not to use an oil under 5W-30 but to use nissan factory turbo x oil.
pic three.
top left starts with things to be carefull of before driving.. then theres a cluster of unknown kanji which i guess says this car has a something something *maybe catalytic converter but definately something to do with the exhaust*attached and you should read the intruction manual carefully and pay special attention to the following 2 points.
point 1.. if the exhaust temp light comes on while driving you should slow down until it dissapears.. or if your stopped and it comes on after revving the engine you should lower the revs of the engine.
point 2.. if the exhaust temp comes on and stays on then you should take your car to the shop for a checkup.
RIGHT HAND SIDE COLUMN
basically a checklist of things to do before driving..
check the following.. feel of the break peddel, break reserve/resevoir tank level??, park brake lever feel, tyre pressure etc, if theres any water or oil or petrol leaks??, condition of the fan belt, idicators working or not and clean or not, that the number plate is secure and clean??, rearview mirror visibility??, shit you were worried about after the day befores perusiling??
number 2/3 got me a little but basically saying to write down the results of the check and make sure you hold on to that paperwork as you might need it sometime..
rough without a dictionary but thats the jist.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
