Hey guys,
firstly,just new to this forum so i thought i'd say hi to all of you guys, secondly my dad has just purchased a 1988 HR31 GTSX, its got an R32 engine(RB20DET ECCS)
HKS GT2530 turbo, GTR front mount inetrcooler, custom inlet manifold, walbro fuel pump, davies craig thermo fans, kakimoto exhaust system and stacks more in the engine bay, on the outside its panther black and has some Works racing harts, anyway, ill try post some pics of it, oh and it made 240rwkw on 14psi on the dyno so it should run low 12's, by the way i'm 13 and very much into cars so i'd like to share my knowledge and learn some stuff also with you guys.
cheers Tom
https://www.sau.com.au/forums/topic/53773-just-got-a-skyline/
Hey guys,
cheers Tom
Sounds like he bought Matt Barne's old car. Awesome looking car.
Excuse me did you say you WERE 13?
IF so firstly why are you buying a car like this when its gonna be 3 years till you drive it?
Secondly who bought it you or your parents, and if your parents did which i'm guessing they would of what parent in their right mind would buy their kid a 240rwkw car as their first?
Danger is the first word that pops to mind.....
BUT on the brighter side welcome to SAU
oh and the car will be made to drift spec soon, so it won't be street legal, ill have to get some el cheapo car, better than nothing
Why oh WHY would you turn something as clean as that into a drifter??? :chop: OMFG!! Its CRUEL DAMMIT!! :confused: :confused: :chairshot
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
