not to be mean or anything, but there is this thing called the internet. Now with this internet you can check out all kinds of information, alot of the stuff you want to know can be found on this internet, and all of it could probably be found on skylines australia. However to make things easier, cause you don't seem to wanna search for it yourself, there is this place on the internet called google, now it's kinda like a big ol search tower, cept it can find anything anywhere on the internet. So just type all them things you wanted to know into google, maybe even with a 'what is...' infrount and all shal be reveiled.
voodoo stuff if you ask me
thanks for the help dickhead but why do you think i came to the forum?
search results came up with 2000+ sites that dont answer what i ask.
If you weren't willing to help then why type what you typed in the first place.
If you didn't realise, the title of the thread = "a little help please..."
You were no help.
Cam gears: When the engine is a RB**DETT the D stands for double overhead cams. The gears are the Two cogs side by side. IF you wish to adjust timing you have to buy aftermakrket cam gears such as a HKS to change it by a couple of Degree's which could increase horsepower.
Conrods, sorry mate cant help ya there
Headers: Passing on to someone else lol
Injectors: Injectors are used to "inject Fuel". The lager the injectors (eg 750cc is big) The higher flow and less restictions. You will need aftermarket inhectors to make big power
Extractors: Sorry
Bleed Valve: A mechanical device that is used to boost a car. It is like a Boost controoler exept it is Mechanic and not Electronic.
And please dont be calling people dickheads.
Cheers
Conrod for short or Connection Rod.
They connect to the piston in the cylinder block at one end and connected to the crankshaft at the other end.
Goto http://auto.howstuffworks.com/engine4.htm and then look at the moving diagrams. :)
Extractor is an exhaust manifold. The turbo connect's on to this and the extractor goes onto the head (of the motor).
:D
Jun
Cam gears:
Provide the means of driving the cams from the timing belt or chain.
Conrod:
Connects the crank to the pistons
Headers/Extractors:
The exhaust manifold, the exhaust gases to flow away from the engine via this. Headers for a V6 pictures (one pipe per cylinder, 3 cylinders per side). Connects to the turbo in turbo charged vehicles.
Injectors:
The ECU/fuel management system pulse the injectors when they need to fire fuel into the combustion chamber. Fuel pressure is fairly constant behind the injectors so when they are pulsed open fuel is injected.
Bleed valve:
A boost control device used in turbo charged vehicles. You can use one to modify the intake manifold pressure required to activate the turbos wastegate. Manual bleed valves are quite primitive.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
