  • Replies 49
Here's that site I couldn't find the other day with sound samples of various bov's. The sound quality isn't too great but you get the general idea. Personally I think the GReddy Type R sounds best, but I don't know if that's just because my car came with one and I'm used to it, or the previous owner thought it also sounded cool and I was therefore lucky to get it :P
http://www.alltrac.net/tuning/blowoffvalve.html
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-82852
Hey that supra wastgate link- the fluttering in between gear changes:- does anyone else think that sound is purely the chopping sound from the turbo due to reversion?!
Many ppl think that is a blow off sound, but if you think about how most of them work, it dosnt make sense if they made that sound- the valve would have to be bouncing open and closed!
In between gear changes, the pressure in the inlet tubes suddenly increase due to the throttle body closing, which usually pushes the blow off valve OPEN. As soon as its spring pressure overcomes the inlet pressure, the valve closes right? and once its closed its not gonna open again anless you boost it and back off again.
Please correct me if im wrong, but i think i may have it figured! Fluttering= reversion -not blow off sound??
cheers
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83299
thats interesting about the piping theory, as mine only made the sound after the FMIC went on.
I reckon i have the answer though ;) :-
How about the fact that with all the new piping and a big cooler core, you have more than doubled the volume of air in the inlet tract, so this extra air, if not let out by the BOV, will have to work its way back out through the turbo (flutter) and out the air filter, just as classic reversion!?
Thats why most skylines flutter at low boost, as the pressure was not high enough to trigger the blow off, and hence, puh puh puh puh puh puh(flutter).... This is the sound that VL turbos WITHOUT BOVs make really well! :)
Exstatic,
Are you saying that the factory BOV's are adequate? or that you dont need a BOV at all?
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83576
This is my undersatnding (and experince) of it:
If the BOV is too tight (or simply not enough pressure to open it), the air will travel back through the turbo, get chopped and make the flutter.
If there is enough pressure to open the BOV (or the BOV is really loose), you get the psshht sound.
SLY33 I think you're on the money when you say...
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83669
my friend has the flutter sound on his s14
he just disconnected the vacuum hose on the standard bov (therefor bov is not working) and i guess the air gets pushed backwards thru the turbo making the flutter sound. the sound really only works if you rev alot.
i also tried it on my 33 and it made a similar sound.. not exactly the same. but after boosting it and i come to a stop the car stalls. getting mixed air/fuel i think
wonder why skylines will stall and 200s dont
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88121
Yeah the car stalls due to reversion. Air passing back out through the turbo cools down the element on the AFM causing the engine to run ruch.
I beleive there are two causes for that noise both result in reversion.
1. BOV to tight, causing air to get bounced back from the throttle body then through the turbo and "getting chopped" by the compressor blades.
2. FMIC installed, volume of air is increased substantially and air cannot escape out of the BOV fast enough causing it to reverse back into the turbo then once again air gets the chop.
Doc
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88290
nah read my earlier post
my friend disconnected his vacuum hose that runs to the standard bov. therefor making it not work creating reversion and fluttering.
i tried it on mine too, but after giving it a hit and coming to a stop it stalls.
both of us do not have any aftermarket bov.
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88340
my R33 has a K&N pod filter, and it makes a fluttering noise when I take my foot off the pedal. Quite a nice sound really.
I've also got a Greddy Type S BOV and it makes this "lazer" high pitch noise when the car is on boost (when changing gear). Both goes really well together...
CBB
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-90597
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
