  • Replies 49
Here's that site I couldn't find the other day with sound samples of various bov's. The sound quality isn't too great but you get the general idea. Personally I think the GReddy Type R sounds best, but I don't know if that's just because my car came with one and I'm used to it, or the previous owner thought it also sounded cool and I was therefore lucky to get it :P
http://www.alltrac.net/tuning/blowoffvalve.html
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-82852
Hey that supra wastgate link- the fluttering in between gear changes:- does anyone else think that sound is purely the chopping sound from the turbo due to reversion?!
Many ppl think that is a blow off sound, but if you think about how most of them work, it dosnt make sense if they made that sound- the valve would have to be bouncing open and closed!
In between gear changes, the pressure in the inlet tubes suddenly increase due to the throttle body closing, which usually pushes the blow off valve OPEN. As soon as its spring pressure overcomes the inlet pressure, the valve closes right? and once its closed its not gonna open again anless you boost it and back off again.
Please correct me if im wrong, but i think i may have it figured! Fluttering= reversion -not blow off sound??
cheers
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83299
thats interesting about the piping theory, as mine only made the sound after the FMIC went on.
I reckon i have the answer though ;) :-
How about the fact that with all the new piping and a big cooler core, you have more than doubled the volume of air in the inlet tract, so this extra air, if not let out by the BOV, will have to work its way back out through the turbo (flutter) and out the air filter, just as classic reversion!?
Thats why most skylines flutter at low boost, as the pressure was not high enough to trigger the blow off, and hence, puh puh puh puh puh puh(flutter).... This is the sound that VL turbos WITHOUT BOVs make really well! :)
Exstatic,
Are you saying that the factory BOV's are adequate? or that you dont need a BOV at all?
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83576
This is my undersatnding (and experince) of it:
If the BOV is too tight (or simply not enough pressure to open it), the air will travel back through the turbo, get chopped and make the flutter.
If there is enough pressure to open the BOV (or the BOV is really loose), you get the psshht sound.
SLY33 I think you're on the money when you say...
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83669
my friend has the flutter sound on his s14
he just disconnected the vacuum hose on the standard bov (therefor bov is not working) and i guess the air gets pushed backwards thru the turbo making the flutter sound. the sound really only works if you rev alot.
i also tried it on my 33 and it made a similar sound.. not exactly the same. but after boosting it and i come to a stop the car stalls. getting mixed air/fuel i think
wonder why skylines will stall and 200s dont
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88121
Yeah the car stalls due to reversion. Air passing back out through the turbo cools down the element on the AFM causing the engine to run ruch.
I beleive there are two causes for that noise both result in reversion.
1. BOV to tight, causing air to get bounced back from the throttle body then through the turbo and "getting chopped" by the compressor blades.
2. FMIC installed, volume of air is increased substantially and air cannot escape out of the BOV fast enough causing it to reverse back into the turbo then once again air gets the chop.
Doc
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88290
nah read my earlier post
my friend disconnected his vacuum hose that runs to the standard bov. therefor making it not work creating reversion and fluttering.
i tried it on mine too, but after giving it a hit and coming to a stop it stalls.
both of us do not have any aftermarket bov.
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88340
my R33 has a K&N pod filter, and it makes a fluttering noise when I take my foot off the pedal. Quite a nice sound really.
I've also got a Greddy Type S BOV and it makes this "lazer" high pitch noise when the car is on boost (when changing gear). Both goes really well together...
CBB
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-90597
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
