  • Replies 42
That is a bummer to hear, mine arrived in 3 days, no prob.
I bought mine off  smtsydney ( I think his name was eric), same guy?
yea same guy , he had great feedback until about a month ago but now its all gone bad with heaps of people complaining
just goto your local exhaust place and ask for a 3" turbo back system. make sure they do front/dump pipe and do 3" all the way. less fuss, less screwing around, less waiting for crap to arrive and youll get it cheaper. i got 1200 for a full 3" system turbo back fully installed, who cares about brand, its bloody metal and its an exhaust im sure it flows fine most exhaust shops hate jap kits cos they are shit quality
including barrell and hi-flow cat.
Read my review (post 18) and take a look at the pics (post 19), yes they come with everything from the turbo.
Yes, $700 delivered.
Yes, they are just as good quality as most systems that you could buy for $1500 or more.
WTF?!?!
ive had ringwood performance exhaust (melb) and glenroy exhaust says jap kits are crap and its crap steel, much better to just get your local exhaust place to do it
of course providing the price is similar. then you dont have to worry about fitting it, parts matching sizing etc as they do it all
those guys are on crack ! they obviously want you to buy one of their exhausts
i have a japanese fujitsubo power getter on my s15 and its by far the best quality exhaust I have ever seen . this think is a work of art ! Ive even had workshops who were working on the car comment on the exhaust .
but these xforces are great value
if I ever get it ......
I would be one of those people!
I didn't buy an exhaust off him though, he didn't respond or send my item until I filed a fraud report against him on ebay.
did you get your item ?
i just got my exhaust after 1 month and 2 days . looks nice , muffler is good quality , very nice looking . other pipes look good . would definetely recomend xforce!
but my cat is purple . wtf ?!
he has claimed the delay was to do with xmas/nye break and he was o/s and everything but still .very poor comunication never responded to emails and i had to call him like 5 times on his mobile
it seems to have all gone to shit this last month but previously his ebay record was tight
what exactly happened give us the story .
I got my item 3 weeks later.
I paid immediately, he didn't respond for 2 weeks until I told him I'd reported
him, then he said there had been a mix up in 'accounts'. What a laugh he is the accounts dept.
I got a stainless 3" turbo back with a 4" tip from Just Jap in syd.... it was piss easy to fit, hardest part was getting off the old one......... i think stainless is the go no rust and will prob last a lot longer then mild steel.... if you have the cash, big up the good stuff.....
  • 8 months later...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
