  • Replies 41
Are those prices for real????
But yeah you have the idea of what I want to do - raise the height of my stock wing.
But thanks - I knew those extension exisited but we couldn't find out WHO made them. But for those prices forget it. I'd rather buy a whole c-west wing and have the choice of using the whole wing or just the uprights - and I'd still be saving money.
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061039
Doh... that price HAS to be for the whole wing...
I read it as ¥20,580... somebody has to sell them or copies of them.
I guess you could get some copies made. But as I have recently experienced, getting things made is a painful experience.
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061058
Yeah my biggest concern about getting something MADE is having the wing fall off under load down the main straight of Phillip Island. What I want to do will put greater pressure on the wing - which it why I really want to look the uprights before I buy them.
The stock wing is quite big and I think it would do a fantastic job on the track if it was just at a more useable height.
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061111
Snow.
My next project after the Turbo ducts is actually replacing the standard plastic uprights on the GT-T wing with Billet Machined Aluminium uprights which I will design myself.
I'd assume that the same bolt holes would be used on the boot of the GT-T (as the factory would punch the holes) but the top might be different.
I wouldn't thin kyou would have to worry about the strength. I will be making then about 8mm wide and very ridig.
They will be bolting into the boot with a bracket on each side, not just on one side.
I'll let you know when I get closer.
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061128
Everything about that upright looks good - except for the base. Looks like its just glued on! And that scares the crap outta me! LOL.
Check out the c-west design. Very sturdy uprights and as you can see a large area where the base fixes - similar in area to the R34 stock ones you can see in the mines extensions above.
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061175
Guest RedLineGTR
dam what a price for "mines" branded items...dam checked the JUN website but still shocked at the price they want :D (92,400 Yen)
http://www.junauto.co.jp/products/aero-par...ar-spoiler.html
Also looking around the forums this r34 gtt is for sale more to the point of the gt wing that it had on it........
Check the thread for better bigger pics :(
http://www.skylinesaustralia.com/forums/sh...ead.php?t=39278
It also states that the gt wing was/is removed maybe he has it for sale?? the boot mounts seem to be more solid.
Cheers Rob
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061253
I've PM'ed the owner of that car and asked to come and have a look at his wing.
What I did notice though it that his particular mounts aren't in the standard location.
They are much closer together.
I might just go and pull my wing off now and have a look at some stuff.
I'll be back.
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061277
Ah, just had a look and it's not as easy to remove as I thought.
I will have to remove all the trim underneath the boot and pull the top off the wing and all that crap.
It's a hour's job to get it off and on again....
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061287
i've got a honeycomb aluminium T wing (not the moulded carbon style). Sits about 15-20 cm above the boot and has an adjustable aluminium mount n all. Looks similar to the Jun one, just lower. If you wanna check it out I'll bring it to the next meet.
https://www.sau.com.au/forums/topic/54132-gt-wing/#findComment-1061424
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
