hey guys.
my clutch had its time, its time for it to go :flamer: .. i was wanting to change it for something to handle around 500hp in my r33 gts25t
whould anyone sugest a dubble plate clutch? brands would be a help to...
is a triple plate not worth for an everyday drive?
thnx in advance
:jump:
https://www.sau.com.au/forums/topic/54162-what-clutch-do-u-use/
Guest two.06l
hey guys.
thnx in advance
:jump:
why dont you pm 2rismo and ask him. I know exactly what he will tell you.
I've driven an OS twin plate.. It is very very nice. :wave:
Pedal is light and it grabs hard but still has a little give for nice street driving.
Ceramic single plates can be a pain in the arse.
But the twin plate is double the price of a ceramic single plate.
cameron Extream 5 Puk single plate clutch with pressure plate, Sprung center - Around $800
with that 5 spuk single plate. i was looking at one from just jap and there are to of them that got my attention. the 5 Button Ceramic and the one next to it but i duno wat one is betar
could they possibly do a good job?
thnx :cooldance
I have the same clutch as Cameron........i can't speak highly enough of it........it holds well, bites well, yet is VERY comfortable to use on the street.
The problem with multi polate clutches is that they wear out just as quick as a single plate........yet cost twice as much to purchase and/or re-co...........
Guest two.06l
thnx :cooldance
id listen to what i am telling you, pm 2rismo. That is if you want the best clutch for your money.
Yeah but it's about the appropriate part for the application. You can't honestly say that clutch is going to be the best clutch for every purpose? Is so I want one, as long as it's adjustable, can hold 1200hp, and has a chev input spline :D
Guest two.06l
im sure jim could knock one of those up for you. I know what id rather buy ,a clutch that has been properly set up on a test bench to suit each application or some generic crap that clamps all over the place and is not set up correctly.I know what im talking about on this one doughy'.
I gota brass button, is great. Was a little stall prone at first but you get used to it like all things, very on/off thats for sure. I was driving my dads corolla for only a couple days & when i went back to my skyline it really made me realise how on/off my clutch is compared to a normal car.
italia spares??? what exactly are they?? are they a spare parts wrecker or a clutch specialist???
iam am also interested in a clutch for my GTR which is slipping on fourth and fifth gear. This Jim Berry fellow how do i get in contact with him? ive notice that u guys live in new south whales, have u met this imfamous jim berry in person? u quoted that he test each clutch on the bench for a particular application? is there a web site showing this or is it what his said over the phone? i believe lee wah has used one, is this why there is such a big hype? i dont see why any competant clutch place cant build a clutch to your specs especially in NSW, i always thought they would be a step ahead of the MAROONS :/ i just wanna make sure there good?
Honestly how can u say a clutch is good until u thrash it and then, it will tell u how many kms it held up for and what power figure it was good for? obvioulsy a more aggresive driver will go through a clutch more quickly then a conservative driver?
Is it true multi plates wear out as quick as single plates?
i ve spoken to Jim and he also rebuilds twin plates??? has anybody experienced this..... not to sure what he was going on about... Adrian can u help me out?
is it the compound that makes these clutches good? or the clamping pressure? whats this slip business?
or do i just go for a OS rebuild kit? :/ anybody had any experience with this pathway?
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
