Jim Berry has been building clutches and clutches only for more than 26 years.
He builds the control clutch for the V8Brute Series in Australia (i.e. the clutch that goes into every single competitors car).
He has built clutches for V8 Supercar teams, Full on drag cars and many many many competitive and championship winning circuit cars/teams.
He is able to re-build and/or modify just about anything you can show him including multi-plate clutches.
I have total faith in his products, expertise and advice. Until someone with MORE experience in this field comes to me and suggests that they know better than Jim (this person doesn't exist), I will continue to buy my clutches from him and recommend others do so too.
In short, I have a vastly superior clutch to what I had in there before and it didn't really cost *that* much more.
Adrian
In a GTST/GTT (2wd) we use OS Giken Twin Plate, they make a road version that doesn't rattle when unloaded.
In a GTR (4wd) we use OS Giken triple plate.
In Sydney the clutch guru is Steve Thompson at;
PENRITH BRAKE & CLUTCH SERVICE
143 Coreen Ave Penrith 2750
(02) 4721 4893
OR... (02) 4732 1046
(02) 4721 4893
Gday Gary
what are ur thoughts on the rebuild kits? or is it better to get a new one? (application is ~350rwkw...currently slipping with twin, would an upgrade to triple be required?)
do the credentials of STEVE THOMPSON match that of JIM BERRY ;)
thanx
Steve
In a 2wd a twin plate would be OK at 350 rwkw as long as it is in good condition and set up properly. As for rebuild, the pressure plate and intermediate plate need to be serviceable, that means not needing or able to be machined. If they are not, then a complet new one is cheaper. Clutch plates are rebuildable altough most times we end up with a new pair.
I don't know Jim, but Steve is closer, does plenty of race cars and has been for many years, he raced/rallied himself. I haven't found any reason to go elsewhere:cheers:
  • 4 weeks later...
Extream 5 Puk single plate clutch with pressure plate, Sprung center - Around $800
I have the same clutch as Cameron........i can't speak highly enough of it........it holds well, bites well, yet is VERY comfortable to use on the street.
The problem with multi polate clutches is that they wear out just as quick as a single plate........yet cost twice as much to purchase and/or re-co...........
It sounds as though thats the clutch that was installed in my car...my advise dont go drag racing with it...the fact that it didnt handle pretty casual launches makes me think how it will go loaded up in 3rd and 4th gear at the circuit. It seems to be a decent clutch for street driving, but it is nowhere near as good as the UAS GTR puck clutch that was in the car:(
Steve Thompson did my three button sprung center clutch . It uses sintered iron buttons rather than sintered bronze . I got three years out of it and its been rebuilt and in my current car . Steve was good enough to take me into his work shop and plan a clutch around my needs . From std to extreme I would not go anywhere else .
Cheers , Adrian .
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
