There was supposed to be some getting set up on the M4 west of sydney around May this year for a 1 month trial where ofenders were issued a warning during the first month and then straight into full use.
I can only guess that it never happened because i would definately have received something by now.
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1063338
Nah, he'd probably just be involved in a crash caused by one of the numerous other, almost un-enforced dangers of driving, or by someone who is either too busy watching their speedo to notice traffic, or is of the growing-in-popularity mentality that if they're not speeding, nothing can happen to them.
Isn't Victoria's road toll the highest in years, despite having harsher than ever speed enforcement?
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1063382
those cameras that monitors the time and speed of trucks on the highways.
It will be used on cars soon also.
:chop:
You mean those SAFE-T-CAM things??
i remember one of the first times i did a long trip, i had no idea what they were so i slowed to the speed limit thru each one...realised later they were for trucks :Oops:
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1063617
another dumb idea about making money. imagine if you dont have cruise control... or even with it...high stress freeway driving!
*oh no i am going 125 instead of 110 down this hill, better brake suddenly and cause a 40 car pileup because all the mums in falcons behind me are tailgating*
every time i have driven along the m4 during the day i have been tailgated, never by p platers majority of the time by females in large sedans. scary.
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1063997
yep - those things, but now for cars. I usually stick my fingers up when i drive though just to let them know that im awake.
wouldnt this be an infringment on the privacy laws ?
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1064240
  • 4 weeks later...
The Point to Point speed cameras are already on the M4 in sydney between the cumberland Highway overpass and the bridge that goes over church street. They arent very easy to spot though, on the cumberalnd highway overpass, they are almost tucked up under the advertisement sign on the bridge, as you approach look up, your on camera :). they look like the digital cameras in the bottom pic of the below link. The second set of cameras is on the existing safe-t-cam and variable speed limit sign framework just on the beginning of the bridge over church street. As the site mentions the cameras are only on the eastbound route. Theyve been very tricky about installing these cameras and hiding them, and legally they need not add extra signage drawing attention to them as they use the speed camera warning signs for the cumberland overpass speed cameras to cover their asses (hence only eastbound). They really didnt want anyone knowing what they were up to till its too late, as the website states they will be activated ~june 2005.
http://www.rta.nsw.gov.au/roadsafety/speed...mera_trial.html
https://www.sau.com.au/forums/topic/54221-rta-romours/#findComment-1093784
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
