Mine has made 200rwkw (197,200,200 on three seperate dyno's) on standard injectors. I must admit though, the tune was quite lean. It has got a Bosch 040 in tank pump, and no form of fuel pressure adjustment apart from what the pump delivers. Dunno how, as your calculations seem to point to them being un-able to make that sort of power?
P.S -thats my qoute about the 18psi :D
Chris
@ 100% duty i.e. not giving the injectors enough time to open and close and given you only have less than 40kw loss...yes this is possible!
But highly not recommended 90% is still OK...but tuners will do it at 60-70% duty, over here anyway.
My bet is that isn't far from the truth, its the most feasable and lateral answer to the question :D If that was the case, there is bound to be a few more around
Most people's injectors are covered with a bit of filth and are hard see without removing them, I will keep a eye out for other RB20 injectors and see if I can find another!
If they were CA or GTR injectors, there would be a ballast resistor attached to the loom somewhere, so I stand by what I reckon - ran out of red colouring! :)
Chris
@ 100% duty i.e. not giving the injectors enough time to open and close and give you only have less than 40kw loss...yes this is possible!
I am pretty sure they where near on 100%, as soon as the fuel filter became the slightest bit of dirty, it would suffer light detonation - new fuel filter and some injector cleaner in the tank and all would be good
The car would backfire and flame alot when I came of the throttle, suggesting to me the injectors where working 100% of the time and there would be a little bit of fuel still entering the cylinders after I had lifted of the throttle
hopefully the new injectors will need no more than 60% to make 200odd rwkw
Chris
What injectors did you go Chris?
Let me know how the fuel consumption goes with them. :D
I went 440cc GTR in the end, and wired in the resistor pack etc, I figured it would be plenty for my RB20
So far with the PFC closed loop function, fuel economy is around 10 litres per 100km, about a litre per 100 better than with the re-programmed ECU :D The PFC closed loop function is first class, providing it is setup right
In the injector correction section (cant remember exactly) there is a correction and lag setup, if you work out the percentage differance from stock and enter this value in - for me it was 58.5% and the injector lag time, in my case -.12ms, it runs better than ever before and delivers quite good economy
The injector lag/cc table for standard nissan stuff can be found here - http://www.ap-engineering.co.jp/el/inj_top.htm
Its being tuned shortly for more boost etc, but hopefully the economy will remain similar providing I dont use the loud pedal too often :)
  • 5 weeks later...
The most common upgrade for RB20's are the 444 cc GTR injectors, with the GTR resistor pack to match the impedance, they are a good choice at realtively low cost as there are many around.
:P
In practice, what is the maximum power achieved with 444cc GTR injectors? I am searching through the forums right now, but may as well ask at the same time.
Reason being, I am going shopping for some parts on the weekend and there doesnt seem to be much price difference between R34 GTR injectors or aftermarket 550cc injectors here in Japan, so I could go either way. I do not want excessively large injectors though and my realistic power goal is 250rwkw from my RB30DET.
Opinions on this choice with fuel economy and idle in mind?
EDIT: Found it ~270rwkw. Opinions still welcome.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
