Hi guys im looking at buying a Skyline For my first car i want a R31 about but i want the TURBO got any advice on how to tell if the R31 is the RB20DET and the RB20DE im not that great when it comes to cars all i like to do is drive em oh and is there much of a power difference between the na and the turbo? i found a R31 1988 silhouette for Aus$2400 not sure what engine yet :P any help will be greatly appreciated.
Thx Brendan
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/
have you looked into insurance yet? for a 1st car, a turbo might not be the best option..
i don't think any australian car came with the 2L Turbo, just the 3L RB30E engine, for a turbo, you will need to find one that has been converted, or an import.. or do it yourself.. either way would expect insurance to be a killer
i am pretty sure the RB20DET have "ceramic turbo" written on the cross pipe above the engine..
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064651
Silhouette is the Australian built model and will have the RB30 engine unless it's been 'converted' to turbo which is unlikely for those sort of $$$
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064695
check out justjap for frontcuts, i know they had one a couple of weeks ago (it was a redtop)..
you wouldn't bother fitting a 2L non turbo, it would be gutless
your other option could be to drop a RB25DET into it :(
do a search here, or on r31 forums.. i am sure there is plenty of stuff out there
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064851
Even if you could do most of the work yourself a conversion wouldn't be the cheapest way to get a turbo. Motor, G/Box, ECU wiring, exhaust, brake upgrade, engineer's certification plus whatever labour etc $2.6K won't get you anywhere near it. You might manage to pick up a tidyish import turbo for $5K I've seen a few auto Passages (4door pillarless) go for that money. Manuals and coupes are harder to find for that money. A very tidy manual coupe with a few mods and some nice wheels probably won't leave much change of $10K
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064858
Your cousin should check out the car before you lay out any $$$...particularly the diff as they are prone to be very noisy/whiney (a known problem). Silhouette model should also have an LSD. R31's are solid, reliable cars when well maintained, but it's still 15+ years old and should be throughly checked.
[this is the part you won't like] AFAIC since this is your first car, you should get some experience with it in its standard (ie NA) form before going down the turbo path, not to mention the fact that getting insurance is going to be difficult and expensive.
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064864
Like it has been said,
The oz released R31 all came with an RB30E, about 114KW
The import HR31's came in RB20 Turbo and non turbo variants. The DET pushes out about 140KW+, while then N/A only does somewhere between 100KW - 110KW.
5K will probably get you an N/A import R31, coupe or sedan, but these are gutless as hell, no top end and no torque. You'd better off buying an N/A local R31, and save up money and mod that, or maybe do a VLT setup yourself.
You will be hard pressed to find a turbocharged import or local for 5K. Either fork out the cash for one already setup, or buy a stocko and DIY.
The other thing to think about is how you are going to maintain it? While 5K might get you an import, it will be barely there on the mechanical side, even still if you buy something else, theres rego and insurance to think about also, not to mention fuel costs.
Visit www.r31skylineclub.com you will find a wealth of information on the forums, just use the search function :( hope that helps
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064927
If it's your first car, then the NA RB30 is fine.
I'm suprised that predator was the first person to mention turbocharging the RB30.
If you've found a Silhouette for that price, grab it while you can.
Drive it around for a while, familiarise yourself with the car, and then chuck a turbo on it
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1065068
spend a couple of hundred bucks on an advanced driving course, and just get use to the car..
better to have some money tucked away in case you find something wrong with the car...
then later on down the track look at upgrading etc..
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1065092
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
