hmmmm everytime i can afford new wheels something goes wrong and my money goes elsewhere. but if i could afford new wheels... hmmm i dont really know anymore. some say chromies others say lightweight racing style and one said spinners. i recently had money again for wheels but again some hidden bills and fines came to me so i dont really have a chance to decide what wheels to get. so just gonna spend what i have on a bov and filter b4 the formals
and just call me chris
