Just saw that report. That lady they kept quoting was rather annoying, it would be nice if she got her facts straight. She said there is no driver education in school, however in the ACT they were trailing a program called 'Road Ready' that i took part in. It was mandatory for all students in my year to go through and pass before they got their L's, and focused on things like speeding and drink driving.
Further more, i wish that some of these people would stop looking to pawn the blame off where it doesn't belong. Ok, so imports didn't rate a mention, though i swear they showed a wrecked Skyline, but the SS commodore and Falcon GT copped a beating. Wasn't the focus on young drivers? How many young driver (i.e on P plates) do you know can afford these two types of cars? So the ads depict them speeding, or gives the impression of speed. Any idiot knows not to speed, blaming a commersial is just down right lame. Ah well. My two cents.
Yea, here in Victoria we have an L-plater education system called "keys please"... she makes it seems like there isnt any education at all. There should be more though like compulsory driver education in high risk situations ect.
Now they're blaming the commercials for the recents deaths. Jeez... they'll blame anyone as long as its not themselves
That was a really wierd and stupidly put together segment.
They go on about how P platers are inexperienced bla bla bla, leads to crashes. Then try to blame car adds because of this. wtf?
It makes no sense. How does a snazzy car add lead to inexperienced drivers dieing? The reason that girl was invovled in a car crash is because of pure stupididty. You do not stop a car in raining conditions in the middle of road when theres poor visibility, u park on the side of the road. DER!
Sooner or later the media is going to run out of scapegoats to pin this on and they'll have to do some real work and research and present the real facts.
When watching shows like ACA and TT you gota remember one thing, they care more about ratings than they do about the truth, so they'll sprout any kind of bullcrap so long as it keeps people watching
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
