Group Buy: Braided Brake & Clutch Lines
  • Replies 108
Just got confirmation email from Maltech today that my brake line set will be in the mail today. They said I should receive it tomorrow or Thursday. Al, thank's for organising this group buy!
PS: Edited - sorry wrong name. Got confused with oil cooler group buy.
LOL Geoff, I hope I'm not going overboard as my car is still a daily driver.... it's just too tempting not to get it with so many group buys recently.
Great to hear all the good reports, thanks for the kind words.
The guys at Maltech are so great that, they have refunded me the difference between the price I paid (2 months ago) and the group buy price. I didn't even expect or asked for it, they just thought it was a fair deal :), I’m so happy.....
Chris you share the same philosophy that I have. I have put a lot of money into handling and braking, yet the engine and turbo are still standard. I have now gone as far as I wanted with these key areas, as I have installed; dba4000's (5000's not avail. for gts-t at the time), braided lines, pads, coil-overs, sway bars, bushes, hicas lock, adj camber/caster, pineapples, etc. Next year I will start looking at some "mild" power upgrades :), the wheels are already in motion (so to speak).
Off topic: what about rims, Al? I got ANZ matrix 17" but I have no idea whether that is lighter or heavier than stock 16" rims... I was told that getting a lightweight rim will improve track handling, but to what extent?
I think grip and width of rim/ tyre combination might be the area to concertrate on more than weight of rims. I think that the difference in weight would only be marginal. But I could be wrong.
The issue with wheel weight is that it is unsprung weight so it has a proportionally larger effect on acceleration (disregarding issues such as better handling) than typical weight.
And the difference can be substantial. A high quality Japanese forged rim can be as light as ~7kg (in a decent size).
LW.
LW.
Agreed. And my black racing wheels only weigh 6.9kg each :)
Mine arrived today so I'm happy. These guys are red hot on the service and Al, you have to be happy with the refund. Now to fit them.....
Having spoken to Steve @ Maltech (who said paying/ordering today is fine), I put my order through just now. Unfortunately National's online banking sucks and the description field is highly restrictive in both length and what you can enter.
Anyway, my description was "SAU lwellsR32gtrBC" which is the maximum characters it would allow me (it also wouldn't allow me to use an ampersand).
Al, for your records, I am after a brake and clutch set for a R32 GT-R in black.
Hope it doesn't cause any problems. Stupid banks :)
Lucien.
Received my braided lines today. I'm happy with it. Thank's Al for organising this group buy!!! They're all labeled as said and got ADR approved stamped on the rubber end cap.
Lucien, just email Maltech with all the details, as described in the second half of the first post, to make sure there will be no confussion.
In all honesty all weight effects car's handling, i just bought a set of cheap 2nd hand track rims and fitted my re55's. My 17x8/9 only cost me $300 for a mismatched set. I am in no competition, but i still will like to kick some people's arse :).
Hope it doesn't cause any problems.  Stupid banks :(
Lucien.
Hey Al, u finally got some 17s and dump ur 19s? Those 19s are way too heavy aren't they?
Hi Al,
Yeah, I did that before I posted. Just wanted to let you know in case they contacted you if there was a problem or other. Got an email back from Steve (top bloke) saying they should be delivered by mid next week :(
Thanks for organising the g/b! :)
In all honesty all weight effects car's handling, i just bought a set of cheap 2nd hand track rims and fitted my re55's.  My 17x8/9 only cost me $300 for a mismatched set.  I am in no competition, but i still will like to kick some people's arse :(.
Indeed it does, but unsprung weight has a far greater impact gram-for-gram than standard weight. When you can knock 5+ kilos off each wheel thats a significant saving in my books.
LW.
1./ Not exactly :thumbsup:
2/ I agree the 19's are not suited to much, just look damn good under the arches :wassup:
Am also considering getting a 2nd set of cheap 17's for drift/burnout as i understeer too much with the std. 16's.
Hi Al, rather than thinking it was the rim n tyres, could it be your suspension setup that's causing it to understeer too much?
U got a nice garage there, looks clean :-)
PS: ANZ wheel just got back to me, each 17" matrix wheel that I have weighs about 12.5kg :thumbsup: that's quite a lot of unsprung weight there, not including the tyres.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
