and rick... i reckon it is a top idea to stay on street tyres....
the street machines white 32 is faster on streets than on slicks due to the fact that with slicks there is NO wheelspin in a 4WD and the motor bogs badly! with street tyres and Altessa there is a nice balance between slip and grip and they go HARD on street tyres.... although a big Exhaust system on that monsta would be a help..... and a HKS 30/37 Kit...... and a Trust Fuel rail....... and Microtech computer..... wait where were we..... yes stay with the street tyres... you'll be quicker and save yourself $$$ when you break stuff....
however 2WD is a different kettle of fish.....
the day that Squizz gets slicks (and a piston.... he he) is the day he runs 11's cause the morose slide states that it is and therefore it will....
and matt if you can go fast as a GTR on street tyres in a VL on STREET TYRES.... i'll give you the silvia to drive cause you must be a gun driver.... all fast 2WD cars run slicks... and that's not cause they are gay... it is cause they want to go fast.... I wish I had enough horsepower to require slicks...
so who is going to the next Day night major anyway....
it looks like it should be a top field with all the brissy guys coming up....
  • Replies 53
I'll probably come to be embarrased by some real gtr's but I was hoping to get more boost and dump pipes and cat removal by then but now some scumbag keyed the gtr while I was at the movies and of course i parked where the camera can't see, I thought they had more than one.
  • 3 years later...
  • 5 years later...
  • 4 weeks later...
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
